Old 06-16-2019, 10:33 AM   #51
Getter-Done
Getter-Done's Avatar
Re: 67 (Crew Cab) C30
I placed the floor the first time here.
This is Pass. side lower A-pillar side.
Driver side lower A-pillar side
And some pliers I modified to clamp the floor to the Toe board.
The early bird gets the worm,
85 Chevy K-20
Old 06-16-2019, 10:54 PM   #52
a.c.ward
very interesting modified pliers, I may have to borrow that idea from you.
A C Ward Retired US Army
66 El Camino
67 SWB underwent major Surgery- http://67-72chevytrucks.com/vboard/s...d.php?t=776475
a.c.ward is offline   Reply With Quote
Old 06-16-2019, 11:33 PM   #53
67_C-30
I have a radical idea!
67_C-30's Avatar
Nice work!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 06-16-2019, 11:37 PM   #54
Getter-Done
I got the idea from my pliers like this.
They would not work without modification.
So I bought a $3 pair + (20% discount )
from Harbor Fr
85 Chevy K-20
Old 06-16-2019, 11:38 PM   #55
Getter-Done
Originally Posted by 67_C-30 View Post
Nice work!
85 Chevy K-20
Old 06-20-2019, 07:30 AM   #56
Getter-Done
Got the floor pan back in location.
Next I will work on the lower A-pillars.
They came in the mail yesterday.
And of course the Cab Footwell Patches.
85 Chevy K-20
Old 06-22-2019, 08:16 AM   #57
Getter-Done
Measuring for my roof cut.
I am still fine tuning the floor fit.
I got these body hammers at a yard sale a few years ago.
Got to find the right ones to fix this gap.
85 Chevy K-20
Old 06-22-2019, 08:20 AM   #58
Getter-Done
This combo of hammer and slapper fixed it.
85 Chevy K-20
Old 06-24-2019, 11:33 PM   #59
Getter-Done
I am still fitting the floor pan.
I decided to bolt in a center hump I got from a swap meet.
I used long bolts and used some of them as studs to
line all the floor pan and Firewall up even more.
85 Chevy K-20
Old 06-29-2019, 10:08 AM   #60
Getter-Done
Here some more progress on my Floor.
First of all, I am still debating on whether
to incorporate the jack handle stamping into
my new floor pan. Of course I would weld
this in under the rear seat. It is the only
solid section in the original floor.
I finally got the big gap closed between the toe panel
and the new floor pan.
The reason this was such a problem. Is the original welds
in the toe panel was not welded very good from the factory.
Maybe a Friday evening or Monday morning (production line) thing.
About 6" up the toe panel and 14' across the bottom there
was a 1" gap when I pulled the floor mat out.
This caused the cab to settle over time.
I have it all Squared Up and fitting again Finally.
85 Chevy K-20
Old 06-29-2019, 10:14 AM   #61
randy500
Looking good and I love the adapted vise grips,too, great idea.
randy500 is offline   Reply With Quote
Old 06-29-2019, 10:28 AM   #62
Getter-Done
This is What helped me the most.
I bolted the best fitting center hump I had.
(without using the Original one)
I used long bolts as studs screwed in from
the bottom
(So I could pull the floor hump down with a washer and nut )
And the bolts I could start from the top side,
I put nuts and washers on them and slowly
tighten the nut and
worked with each bolt till I got the
Trans hump pulled down tight.
This put the toe panel and the floor fit good in the
front center of the floor.
85 Chevy K-20
Old 06-29-2019, 10:37 AM   #63
Getter-Done
Thanks Randy
The other pliers That I found to do
this was to Heavy and was trying to bend
the sheet-metal.
85 Chevy K-20
Old 06-29-2019, 10:42 AM   #64
clay68c10
clay68c10's Avatar
That is a great way to use those cool pliers and the hi hump to get that gap lined up.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 06-29-2019, 11:43 PM   #65
Getter-Done
85 Chevy K-20
Old 06-29-2019, 11:55 PM   #66
Getter-Done
Here's a Picture or 2
of my current Cab fixture.
85 Chevy K-20
Old 07-07-2019, 12:53 PM   #67
Getter-Done
Now that my floor-pan is fitting like I want it too.
I cut some more tubing and drill holes in the tubes
to use the seat mounting bolts
and welded that to my cross-bracing.
So I can remove the floor Again
I chose to do this for easy access
to the foot-well patches that I'm going to
replace. Once I fit both foot-well patches,
I will tack them in & put the floor back.
Then I will repair the lower A-Pillar.
Doing it this in this order I can keep
the location of the 2 lower a-pillar
and lower fender mounting holes in
the ( same ) location.
I used a small dremel tool
on the spot welds. It worked good
for this area.
85 Chevy K-20
Old 07-07-2019, 01:04 PM   #68
Getter-Done
More pictures of foot-well removal.
Used this dremel with cut-off
wheels that came with it
to stay out of the lower A-pillar.
I lined the patch up and scribed
it on the back side for my cut line.
85 Chevy K-20
Old 07-07-2019, 01:12 PM   #69
Getter-Done
My next step will be sand blasting.
and rust treatment.
85 Chevy K-20
Old 07-07-2019, 01:19 PM   #70
Getter-Done
Since I am replacing the Toe-board
I removed the floor braces that
attach to the toe-board for easier
installation of the floor pan.
This is a tool I made too break
the welds loose.
85 Chevy K-20
Old 07-07-2019, 02:04 PM   #71
CG
BlahBlahBlah
Holy moly! You guys that can pull this sort of thing off are amazing. Great job so far.
Old 07-07-2019, 02:10 PM   #72
Getter-Done
I hope to get a little more done today.
85 Chevy K-20
Old 07-07-2019, 03:11 PM   #73
flashed
Wow , great work .
flashed is offline   Reply With Quote
Old 07-07-2019, 03:27 PM   #74
Getter-Done
Originally Posted by flashed View Post
Wow , great work .
85 Chevy K-20
Old 07-07-2019, 10:14 PM   #75
Getter-Done
Got some sandblasting done.
It all cleaned up good.
I need to get some more media.
I Got a little more blasting
work to do.
85 Chevy K-20
