Old 06-09-2019, 07:08 PM   #1
old51sedan
old51sedan's Avatar
Question Vent window handle removal
In the process of redoing my vent windows, I want to remove the roll pins to install new handles. Does anyone have an idea of what to use to drive the roll pins out with? Need something that is small, yet strong enough not to bend. Has anyone had any good luck using anything particular?
old51sedan is offline   Reply With Quote
Old 06-09-2019, 07:56 PM   #2
Molino
Re: Vent window handle removal
I have a can of old drill bits that I use for small punches. Grind off the shank from the twisted part of the bit and lock it in a needle nosed vise grip pliers. If you need a punch longer than the shank then use the whole drill bit with the point ground flat. It always works in a pinch to get the roll pins started moving. A good penetrant helps too.
Good luck,
Russ
Molino is offline   Reply With Quote
Old 06-09-2019, 09:00 PM   #3
Grumpy old man
Grumpy old man's Avatar
if you don't have a small punch use a nail , it only has to come out far enough to grab it with pliers to pull it out .
Old 06-09-2019, 11:17 PM   #4
RustyPile
RustyPile's Avatar
Go to Home Depot and getcha one of these:
https://www.google.com/search?q=punc...=1560136531793
RustyPile is offline   Reply With Quote
Old 06-10-2019, 12:33 AM   #5
rechinca
rechinca's Avatar
There are roll pin punches with a small nipple on the end that keep them centered when driving thes pins out and back in. As well as there are starter ones to hold them when installing. If you have a hard time finding, look at Brownells online as they are great to have for firearms repair too. They are the proper, functional and fairly cheap tool. Amazon has them too. I have used the snot out of mine over the years.
1971 Custom/10 - 350/3 speed, Orange/White roof
rechinca is offline   Reply With Quote
Old 06-17-2019, 05:09 PM   #6
hugeheaderic
SS filler rod cut small, use the size you need
68 C10 SWB 350/350 4 whl discs riddlers never done
hugeheaderic is offline   Reply With Quote
