Old 06-09-2019, 10:41 AM   #26
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Factory Temp Gauge reading?
Originally Posted by gator2511 View Post
I got tired of fighting the printed circuit board so I just yanked it out and hard wired the wires. No problem since then.
I'm about there myself
Old 06-09-2019, 11:49 AM   #27
custom10nut
custom10nut's Avatar
Originally Posted by brown7373 View Post
I live in south Florida and run my A/C. Mine is identical to dmjlambert. And the thermostat has nothing to do with the operating temperature. The thermostat controls WHEN (at what temperature) it opens. There is no difference between an open 160 or a 195. They both flow the coolant the same. Once either is open, the temperature is determined by the efficiency of the cooling system. And is the engine making more than normal heat.
If you gauge is near hot, then either you are in fact over heating or the gauge or sending unit is not accurate. Check it with a known good gauge, or use a temperature gun.
I did that, put in a new 180deg t-stat and even used a thermometer in the open radiator. I let it idle for a good hour and the temp sind the get above 190, so I know the cooling system is working as it should. I ended up tracing the wire and at the firewall, I found the connection was loose(but still connected), and I put a spot of dielectric grease in a clicked it but together. Now my gauge works again
custom10nut is offline   Reply With Quote
Old 06-18-2019, 08:16 PM   #28
garyd1961
In response to brown7373.
Not 100% correct, a thermostat can't control what your maximum temperature will be but it can control what you minimal temperature will be. If you have a motor that runs at 165 a 195 thermostat will raise the temperature to 195.
garyd1961 is offline   Reply With Quote
Old 06-18-2019, 08:33 PM   #29
garyd1961
Deleted.
