Old 05-06-2019, 11:54 AM   #1
PGSigns
PGSigns's Avatar
odd ball wiper issue
The wipers on the 66 were acting up when using the switch (2 speed wipers) every once and a while but worked fine with the intermittent controller I have on it. So I pulled the switch out of the burb to test with and it did the same thing. And yes the switch worked in the burb. Then tried it with the stock wiring configuration and no wipers with either switch. So what it looks like to be is a ground issue, but where I am loosing the ground I can not figure out. Testing for power at the motor it all seems fine and they will run and park just fine with the intermittent controller. Any thoughts?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-06-2019, 08:58 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: odd ball wiper issue
Have no real idea, but doesn't the wiper motor ground at the attachment point at the cowl?
DPowers is online now   Reply With Quote
Old 05-07-2019, 12:34 AM   #3
Captainfab
60-66 Nut
Is your switch grounded well?
Old 05-07-2019, 11:24 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
I think it grounds thru the switch. In fact it has to. How's your gauge panel grounds? So the panel surround either black or chromed (whatever you have) has to have a good ground to the gauge panel housing, then a good ground from there.
Old 05-07-2019, 11:40 AM   #5
PGSigns
PGSigns's Avatar
The panel seems to be grounded well. All the gauges work good along with the lights that use the panel for the ground. I did test it with a ground attached to the switch and the switch hanging down. I do have a new wiper motor that i may just plug in and test the wiring and adding grounds. Just had shoulder surgery a month ago so I have to find a helper.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 05-07-2019, 06:45 PM   #6
Clyde65
Clyde65's Avatar
The switch grounds at the dash. I believe the motors are all on rubber bushings so shouldn’t the motor be grounded at the plug? Physically?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-07-2019, 08:02 PM   #7
grubsster
grubsster's Avatar
The motor grounds using the tab riveted on at the lower left corner of the one in this picture. Maybe a different location on some but that is how mine is grounded.
grubsster is offline   Reply With Quote
Old 05-08-2019, 09:21 AM   #8
The Rocknrod
Moderator
I also have that strap on my brand new motor as well. Funny thing though, I wired my truck like it is a fiberglass body vehicle. So there are no body grounds, I run a ground wire to everything. The motor runs like a top. Strange.
Old 05-11-2019, 03:39 PM   #9
65trucks
I kind of ran into the same issue the other day, even though yours may have a different cause. I put a new instrument panel bezel in with a new gauge panel. Put everything back together and tried everything, but the wipers. So heading to the local cruise in a few days later, it starts to rain. Wipers don't work, at all. I wiggle wires, do everything to try to get it to work. Nothing.
So I did not know the switch grounds thru the new, painted, black, bezel I have. The way I tested it was to turn the switch on, with ignition on, and ran a fused jumper wire to ground. Wipers started working immediately. Took a piece of sandpaper on the back side of the bezel where the switch mounts, and bolted it back up. Works like a charm. Something to check on while you are trying to find a cure.
65trucks is offline   Reply With Quote
Old 05-11-2019, 11:24 PM   #10
Isaiah92260
Isaiah92260's Avatar
On my 61 my wipers work on and off also. I messed around with the switch when I took it off and realized that the switch works if I push it against the base while I’m twisting it on. Doesn’t when it’s not in contact or when I barely twist the knob to the on position. I guess whatever is in the switch that is contact with the rotating knob start to separate over time as these switches get old. I read your original post but I’d like to mention this is to these wipers being operated with original or old switches.
Isaiah92260 is offline   Reply With Quote
Old 05-13-2019, 06:35 AM   #11
PGSigns
PGSigns's Avatar
I have not had time or help to work on this yet. I am getting a new switch just in case. Having the intermittent controller on it does give me wipers just not full speed.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 06-19-2019, 06:54 AM   #12
PGSigns
PGSigns's Avatar
OK I got it fixed finally now that my shoulder is healed enough to work on it. Here is what I found. First make sure you volt meter is not on auto range. What looks like 4 ohms could be 4K olms. I think that is what happened when I tested the switch I thought was good. When I pulled it to start testing everything again it showed open on a 20 ohm scale but 4 on auto. So I grabbed all the wiper switches I had and tested all of them. Three were bad and one good one. Put the good one in the truck and it works like it should. After all these years of working on stuff I made a simple mistake that I should have caught.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 06-19-2019, 10:47 PM   #13
DPowers
DPowers's Avatar
Glad that you got it figured out. If always got it right, you wouldn't need this board.
