Old 06-20-2019, 11:17 PM   #1
CG
BlahBlahBlah
Repurposed 67-72 truck parts used in your 67-72
Seems odd I need to be so specific but I see a lot of threads lately that end up with a whole lot of non 67-72 trucks in this area of the board.
What piece of our trucks have you repurposed for another area of our trucks? I can only think of glove box doors being used for gauge panels and wheel wells being turned upside down for spare tire use.
Anything else cool you’ve come up with?
Old 06-20-2019, 11:27 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Repurposed 67-72 truck parts used in your 67-72
Great Question.
I am in. For This thread.
I am thinking switches and dome lights and ------Wow.
Let me study on that.
The early bird gets the worm,
84 Chevy K-20
Old 06-21-2019, 06:23 AM   #3
cbeerman
The most obvious to me is using a windshield fluid reservoir and mount as a coolant overflow tank.
cbeerman is offline   Reply With Quote
Old 06-21-2019, 06:55 AM   #4
I just can't come up with anything right now. I'm sure there are some to tell.
My friend who bought my K/20 Highlander had a set of original 16" wheels made onto 17 x 9s for that truck.
For my '67 project I have a custom horn button. I bought it, didn't make it. I am using a '67 car steering wheel. This 67/68 GMC Super Custom horn button insert was modified to fit in the car horn button.
Don't people use radio deletes to install post stereos?
Old 06-21-2019, 07:55 AM   #5
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
I used a rocker panel for the bottom of a door. Thicker metal than the patch panel made and usually cheaper.
I have also used a rocker panel for the area under a tool box door as it has the same shape as that area.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 06-21-2019, 08:28 AM   #6
CG
BlahBlahBlah
I have a bunch of large chunks of old bedsides, doors, etc that Im keeping for patch panels. More than likely Ill never need, but they store flat and I can keep them in a smallish area.
Seems like someone took pieces, or just the bottom of a glove box door and mounted it under the heater controls for an aftermarket gauge panel.
Tim ... Remember the undeleted radio delete plate I gave away as a prize on the board a little while back? I think it was actually a pretty good idea by whomever did it.
Old 06-21-2019, 09:24 AM   #7
70STOVEBOLT
70STOVEBOLT's Avatar
I don't know if this counts, but I repurposed two sets of 71-72 bench seat sliders into bucket seat sliders. The only modification I made was cutting off about a 1/2 inch from
the rear of the top curved bracket and re-drilling the holes to mount a piece of angle iron to bolt the seat to. I don't have pics but I can take some if anyone is interested.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 06-21-2019, 09:38 AM   #8
Grumpy old man
Grumpy old man's Avatar
I cut the top curved sections of scrap front fenders to repair the front fender cups ,Also the section of the front fenders where the hood hinges mount that have the welded nuts to repair hoods where they have been cracked / rusted mounts .
Old 06-21-2019, 02:16 PM   #9
LockDoc
The Older Generation
LockDoc's Avatar
I had a door to replace the passengers door on the Panel Truck when I wrecked it. No patch panels for the quarter so I used a pickup door skin to fix that. Fit like it was made for it.....
LockDoc
Leon
Old 06-22-2019, 07:14 AM   #10
I guess that's what I was thinking of... but didn't know it. Undeleted delete, sounds like the little birdies singing outside my window.
That under dash gauge panel is a good idea!
That sure does count.
LockDoc
Good eye on that. Someone made that door skin just for your Panel's quarter.
I love what this person did. Just a fun machine you could build from a crapped out C/10. Shorten frame, a cut here, a weld there, and you have an El Cheapo hop over the side 2wd Cruiser Blazer. I want to built one!
Old 06-22-2019, 11:23 AM   #11
CG
BlahBlahBlah
I have had those pictures saved for a long time. I think its a cool little rig!
Old 06-22-2019, 02:01 PM   #12
So casual... (to steal a phrase from the '70s)
I don't even like bed covers, other than tonneaus, but I always thought it would be a cool custom truck thing to use a hood or many hoods to fabricate a matching bed cover. It would seam along the bedside same as in the front fender and the top of the tailgate. Maybe just the back half would open.like a trunk. Somebody tell one of those rich TV show truck builders so we can see it done.
Old 06-22-2019, 04:44 PM   #13
rjs53
I used an aftermarket steering wheel and horn button. The original wheel is a wall hanger the hen button is the volume knob on my garage radio. Hes I still use a receiver with speakers and a cd player.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 06-22-2019, 09:02 PM   #14
mygmctruck1
Not sure if this counts but I am repurposing a set of Bronco bucket seats for my 68 . They need new mounting frame but there going to be a great seat.
mygmctruck1 is offline   Reply With Quote
Old 06-24-2019, 11:02 PM   #15
Peanut74
Kind of outside the scope of the thread. But I needed a small couch for my man cave so I back halfed a Ford explorer sport box. Wired it up with a 12 volt converter and LED bulbs. A friend sewed up a cushion for it.
I have some '67 bedsides that I am considering doing the same thing to.
Peanut74 is offline   Reply With Quote
Old 06-25-2019, 08:21 AM   #16
Bones72Super
Bones72Super's Avatar
I think I just threw up in my mouth a little bit
WTB 71-72 Original paint Medium Red hood
WTB 1972 Very nice original Parchment seat belt set
Bones72Super is offline   Reply With Quote
Old 06-25-2019, 08:56 AM   #17
rjs53
Now that's funny. But seriously don't cut up the bed sides.
2003 Dodge 2500
1969 C10
Old 06-25-2019, 09:07 AM   #18
I think the cut the ass off a car or truck to make an uncomfortable couch thing is played out. Or I hope it is. First one or two I thought were pretty neat, creative. But now it's monkey see monkey do. I like to see old parts repurposed in use on a vehicle.
Not just that post, but I sure do find it odd that even though CG was very specific, and even commented on that, if you read his post, we still have more of what he didn't want than what he did.
Let's get back to "67-72 parts repurposed on 67-72s", ok?
Old 06-25-2019, 01:03 PM   #19
70c10-08
70c10-08's Avatar
Cool Re: Repurposed 67-72 truck parts used in your 67-72
Well I bought a 69 C/20 in college to repurpose parts for my C/10 build she came with a 4 speed and an oil bath 2bbl 350 well I mostly just reused the 350 block, the no tilt manual steering column, the gear stick, the high hump, and some odds and ends here and there but other than that the rest of the C/20 will be living on as my buddy's C/10 or K/10 build he hasn't decided yet. I had also purchased a 1967 small window former buddy bucket A/C cab from Colorado used the cab but that firewall and dash wouldn't do nor would the floor so I cut up the firewall and installed the proper non A/C firewall components and ditched that A/C dash for the non A/C dash out of my C/10 but don't worry that A/C dash lives on in a K/5 Blazer somewhere
70c10-08 is offline   Reply With Quote
Old 06-25-2019, 05:41 PM   #20
Barnfind46
Barnfind46's Avatar
I thought Peanut had a perfect use for Ford parts! Can't break down if it's in the man cave!
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 06-25-2019, 07:42 PM   #21
Livrat
Member #1049
Livrat's Avatar
Before you could purchase Suburban quarter panels I used two rocker panels, a Blazer quarter patch, part of a door skin and a long fleet bedside wheel well arch to fix the rust in a burb.
Livrat is offline   Reply With Quote
Old 06-25-2019, 07:57 PM   #22
Livrat
Member #1049
Livrat's Avatar
30 or so years ago I used a Longhorn frame with 1/2 ton axles, a 71 GMC cab and nose, a Burb roof, cut the cab off behind the doors and moved the rear portion back to fit up to the bed then used the sides out of a panel truck all combined into an Extended cab truck.
Old 06-25-2019, 09:28 PM   #23
CG
BlahBlahBlah
Thank you special-K, I had to just shake my head when those other things were posted. I think we even had a thread about things like this in the general area awhile back haha.
Livrat (Mark) Im pretty sure I could just fill up a flat bed with random 67-72 truck parts, dump it on the ground outside your shop, and you would build something beyond cool with them.
Old 06-30-2019, 02:23 AM   #24
Fraud
I've been thinking about this for a while but never seen any detailed pics of the end result, can anyone point me to a thread?
Fraud is offline   Reply With Quote
Old 06-30-2019, 03:30 AM   #25
'68OrangeSunshine
'68OrangeSunshine's Avatar
I've had a '69 T-Bird electric bucket back/bench bottom in my '68 C/10 since 1977. I have used my OEM 516 Orange Radio Delete Plate for a radio bezel. I painted it over in krinkle black.
And I've used a sunshade clip for a Coat Hook on the passenger side of my Stepside cab.
