Old 05-03-2019, 04:31 PM   #101
BIGglaSS
BIGglaSS's Avatar
Re: 85 GMC dirt cheap refresh
Oops, thought I saw in another post that you were using SPI... My bad. Either way, it looks good!
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30
BIGglaSS is offline   Reply With Quote
Old 05-03-2019, 04:53 PM   #102
Jaysonb
Jaysonb's Avatar
Im using SPI universal clear coat on the other truck I'm working on, and I also used the universal clear on the truck before that. On this truck I'm using up products that I have left over from previous projects. The grey is 2 diffrent pewter colors, charcoal grey, and black all mixed together. The spi clear is hard to beat, I haven't tried there single stage black, but it gets rave reviews.
Jaysonb is offline   Reply With Quote
Old 05-03-2019, 04:59 PM   #103
BIGglaSS
BIGglaSS's Avatar
OK, so I'm not quite crazy. I have been following SPI for a decade, and been using their epoxy. This summer I will be painting my Dad's car with single stage black. My 57 pickup will get black base / universal clear. (the reason I asked..)
Old 05-03-2019, 06:37 PM   #104
Dads79GMC
Dads79GMC's Avatar
BIGglaSS, you're not crazy.
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 05-06-2019, 05:59 PM   #105
MrFinland
MrFinland's Avatar
Really great job, Jayson! I admire your skills!
MrFinland is offline   Reply With Quote
Old 05-08-2019, 04:25 AM   #106
Jaysonb
Jaysonb's Avatar
Thank you Ilkka! I had some time to play in the shop, and started working on the front end. I got the hood sanded down, and started filling a bunch of little low spots. The left fender was a little rusty under the wheel well trim, it was a nice fender otherwise, so I bent up a patch, and a little time with the shrinker and stretcher, I had a good enough section to weld in, after I cut the bad spot out. It isn't 100% perfect, but it's solid, and the trim will cover it up anyway.
Old 05-08-2019, 08:01 AM   #107
Low Elco
That's the next thing I gotta get, a shrinker/stretcher. What brand is yours, and do you like it?
Low Elco is offline   Reply With Quote
Old 05-08-2019, 11:03 AM   #108
Dads79GMC
Dads79GMC's Avatar
Excellent work!
Old 05-08-2019, 06:53 PM   #109
Jaysonb
Jaysonb's Avatar
I bought my set from eastwood on sale. They work great for the small parts I have used them for. I have a blast using them.
Old 05-14-2019, 07:05 AM   #110
Jaysonb
Jaysonb's Avatar
I shot some paint on the fenders, hood, and other front end parts this morning. I kinda rushed through the final blocking, and it shows with some low spots on the hood, and a small ding in one of the fenders. The finished product will be nice enough to roll with though.
Old 05-14-2019, 12:28 PM   #111
Dads79GMC
Dads79GMC's Avatar
Beautiful!
Old 05-19-2019, 04:15 PM   #112
Jaysonb
Jaysonb's Avatar
I've made a little more progress. Slow but steady!
Old 05-19-2019, 05:01 PM   #113
pitterpat
THAT is a good looking dirt cheap refresh.
1984 Chevy Custom 20
$2500 work done on engine and transmission 2010/ less than 1000 miles on it since.
Here's my mild build thread,
http://67-72chevytrucks.com/vboard/s...d.php?t=783971
pitterpat is offline   Reply With Quote
Old 05-20-2019, 10:36 AM   #114
Rickysnickers
Rickysnickers's Avatar
Yeah, this is not what I would call a "dirt cheap refresh." Although, maybe if I had these kinds of skills it might be . Nice work!!!
Old 05-26-2019, 01:40 AM   #115
Jaysonb
Jaysonb's Avatar
I got the vent windows rebuilt and installed, door glass installed, and installed new carpet, and a new headliner, and have installed most of the stuff I have sitting around the shop that I can. I still have to dye the door panels, and the interior will be done for now. I just about have it weather-proof, so it can sit outside while I get the box done. I also have the box for Mikes (Dads79gmc) 78 here now, so the 85 will go on the back burner while I get that knocked out for him.
Old 05-26-2019, 10:08 AM   #116
Dads79GMC
Dads79GMC's Avatar
Everything looks great Sir!
Old 06-18-2019, 07:49 PM   #117
Jaysonb
Jaysonb's Avatar
I have been slowly plugging away at this truck. I painted up some 7" rallys, and got some tires mounted up on them. I also got a round of body work done on the left bedside. Door panels are re-dyed and installed.
Old 06-18-2019, 10:34 PM   #118
pitterpat
Next to last picture, the hose from the air cleaner, a few questions:
  1. Where did you get it
  2. Where / what does it connect to?
  3. Did you sand blast and repaint the air cleaner. I bought the correct year air cleaner from a guy on this forum, it needs to sandblasted(?) and repainted. What paint did you use?
Thanks, Pat (female)
Old 06-19-2019, 10:08 PM   #119
Jaysonb
Jaysonb's Avatar
The tube from the air cleaner is called a fresh air duct I believe. I ordered it from lmc, and there is a round plastic fitting that sticks through the core support that the tube slips on to. I did sand blast the air cleaner, and primered it with grey rustolieum primer, and painted it with satin black rustolieum.
Old 06-20-2019, 02:51 PM   #120
Dads79GMC
Dads79GMC's Avatar
Looking great!!!!
Old 06-24-2019, 09:47 AM   #121
Jaysonb
Jaysonb's Avatar
Made some progress this morning!
Old 06-24-2019, 01:46 PM   #122
Low Elco
WoooWooo!
Old 06-25-2019, 05:37 AM   #123
Jaysonb
Jaysonb's Avatar
A little more progress!
Old 06-25-2019, 09:16 AM   #124
aggie91
I'm just glad to be here!
aggie91's Avatar
Looking good there Jayson!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-25-2019, 04:17 PM   #125
Jaysonb
Jaysonb's Avatar
Thank you!
