tranny vacume
anyone have any pics on how the tranny vac line runs,i've got the tubing just can't figure it out.also does it plug in on pasenger side of my 1406 edelbrock?
Springvale,Maine 71 3/4 GMC lwb |
Transmission vaccum modulator would be run directly off a intake manifold supply, usually behind carb, directly from intake.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
Recovering Truck Driver
I don't have a pic, but if memory serves correctly, the vacuum line should run along the left side of the transmision, above the pan, up the left side of the bell housing with a clamp that is attatched to the top left bell housing bolt, then connects to the intake manifold via a rubber vacuum line splice....it should go to the tee in the back of the manifold, just behind the carburetor.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
thanks for the info
The vacuum line for the transmission modulator is on the right side of the transmission housing and it is held to the housing by one of the housing mounting bolts with a tab.
If you need a pic, let me know, we have a completed frame with the transmission, etc. in place. Jim |
Not my good side.
I'd like to see a pic. I'm experiencing a problem where my TH350 won't kick up into passing gear, and I suspect it's a vacuum problem. Would be nice to see a photo before I tackle this one. Thanks in advance.
72 Chevy K20 Custom Camper, 350/350, 4" lift, dual shock suspension front & rear. Daily driver and a work in progress. 00 Suburban LT 90 Camaro RS 79 Yamaha XS1100 Special (Ol' Reliable) |
CCRider
I the vacuum mainly controls upshift. If you are not getting any vacuum it would not shift out of first gear. If you are going 45 mph,and stomp it to the floor and it won't downshift, you probably need to adjust the down shift cable.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
so would i tee off brake vacume line?
