06-17-2019, 03:14 PM | #1 |
air bag compressors tripping breaker
installed rear air bags in my 1964,dual compressor ,has 60 amp circuit breaker,with truck running breaker will flip before tank is full @ 90 psi,relays seem warm to touch,any ideas to resolve this?i believe the relays are 40 amp,this was a full air ride kit,but only did rear,
06-19-2019, 11:51 AM | #2 |
Re: air bag compressors tripping breaker
What size wiring? What length between breaker, power source, & compressor/s?
06-19-2019, 07:40 PM | #3 |
I followed schematic shown,6 ga wire is about 7 feet from breaker to relays . should I separate grounds for relays and compressors?
06-20-2019, 02:25 PM | #4 | |
Engine block to frame = Each side of motor has 4ga batt cable to the frame (L&R rails ground to block). BATT @ PASS rail & cab (relocated battery). Frame rails to core support = 4ga (again, both sides). Cab to frame rails = 4ga (both sides). Rear x-member welded to rails.
06-20-2019, 06:57 PM | #5 |
Run a dedicated round and see if that fixes it.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
06-22-2019, 08:16 AM | #6 |
thanks for replies, gonna mess with it this weekend
06-29-2019, 07:02 PM | #7 |
ending up changing 60 amp circuit breaker with a better brand,went to lower psi pressure switch,been working like it should,still gonna add better ground from batt. to frame
