Old 06-25-2019, 12:04 AM   #1
Mike_The_Grad
Mike_The_Grad's Avatar
292 flywheel/clutch/crankshaft dilemma.
Hey all, here's the skinny. I have a freshly rebuilt 292 for my dads 64 c10 LWB sitting on my engine stand. New crankshaft,camshaft, bored over, the whole 9. The crankshaft flange has 1/2" holes. I have brand new 12-point ARP 1/2" bolts to match. I have a brand new LUK Repset 11" clutch kit(pressure plate, throw out bearing, disc,) the flywheel I sent to the machinist to have him resurface has 7/16" holes...
From what i read on this site is yes, i can drill out the flywheel holes to 1/2"
Ok, Maybe a stupid question maybe not, should i use a drill press to enlarge the holes, or can I get away with using my miluakee M18 drill and a new 1/2" carbide drill bit with cutting oil?
Trying to get this figured out ASAP as I'm planning on dropping the motor back in to the truck like tommorow, or As soon as I can. Lol.
Thanks in advance.
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline   Reply With Quote
Old 06-25-2019, 06:38 AM   #2
PGSigns
PGSigns's Avatar
Re: 292 flywheel/clutch/crankshaft dilemma.
You can use either with the proper setup. In the drill press I use a bit with a pilot ground on it to center up the hole. By hand I have used a step drill to get the hole centered as possible.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-29-2019, 10:19 PM   #3
Wrenchbender Ret
Ive done a lot of them. Just take the drill with a 1/2 bit & go through. It doesn't take much. Go slow. If it locks up & grabs, it will jerk your arm.
George
Wrenchbender Ret is offline   Reply With Quote
Old 06-30-2019, 01:47 AM   #4
Mike_The_Grad
Wrenchbender Ret,
I bought the correct flywheel for my setup.
Used three split dowels and new ARP bolts.
All is good.
