Old 06-01-2004, 09:05 AM   #1
lugnut
lugnut's Avatar
88 GMC suburban oil pan ?
Does anyone know if I can drop the oil pan in my 88 GMC suburban, 1/2 ton, 4X4, 350 auto, with the engine in? I need to replace the pan and would like to do it without pulling the engine. It looks like there is plenty of clearance. What do I do where it meets up to the timing chain cover? Anything special that needs to be done? Thanks.
1967 Chevrolet 1/2 ton 4x4
1972 GMC 1/2 ton 4x4
2005 1500 4x4 Suburban
2004 GMC Envoy 4x4 (wife's)
lugnut is offline   Reply With Quote
Old 06-03-2004, 01:26 AM   #2
kwmech
First you drain the oil and second you remove the filter and third you remove the bolts. It is as easy as it looks.
Old 06-03-2004, 03:13 PM   #3
Jonboy
Slots go on anything!
Yep. That should have the one piece oil pan gasket. Makes reassembly a breeze, especially in a 4wd. Why do you have to replace the oil pan?
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 06-03-2004, 06:06 PM   #4
lugnut
lugnut's Avatar
oil pan
totally shreddit the oil plug and cannot get an oversized one to seal...in fact the little du-hicky on the inside of the pan where the threads are, broke away from the spotwelds so there isnt anything to rethread into. Not a big deal, i have an extra pan, but just didnt know if it would clear the front Xmember. Thanks for the help
Old 06-04-2004, 09:02 AM   #5
Jonboy
I was hoping for an off road carnage story.... Replacement should pe pretty easy.
