06-23-2019, 11:53 AM | #1 |
Tailgate bumper
Squared up my 66 SWB fleetside box and have the Mar-K tailgate fitting well (no chains). The tailgate sits on the box metal, no rubber bumpers? Metal on metal will make a mess of new paint in short order. No room to put a bumper as it would push the tailgate out. Is there a trick to fix this?
06-23-2019, 07:26 PM | #2 |
Re: Tailgate bumper
Thinking major surgery to box to allow for room for a rubber bumper? Stock it looks like tailgate rests on box, metal to metal?
06-23-2019, 08:37 PM | #3 |
Re: Tailgate bumper
Got a picture of what your asking??
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-23-2019, 11:00 PM | #4 |
Re: Tailgate bumper
When the tailgate closes, it stops when it hits the metal of the bed sides. Later trucks, 67-72 have a little more room and have a rubber bumper to save the paint. No room to do that on a 60-66. Must be a way? |
06-24-2019, 07:40 AM | #5 | |
Re: Tailgate bumper
Jake Old fart in Western NE |
06-24-2019, 11:58 AM | #6 |
Re: Tailgate bumper
I honestly never even looked to see if there was some rubbing....now I’ll have to look when I get home. I know I didn’t put any weatherstripping there but...
06-24-2019, 02:24 PM | #7 |
Re: Tailgate bumper
i have the same problem... im watching....
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
06-24-2019, 06:06 PM | #8 |
Re: Tailgate bumper
I’m working on mine, I need to look at that. I made a hard rubber bushing with a stainless pin for my hinge so it wouldn’t chip the paint. I know the chains will but I think they give them caricature. The chains not chips
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent |
06-25-2019, 02:51 PM | #9 |
Re: Tailgate bumper
I was thinking of using that clear film that's used to protect the bottom of sheet metal, around wheel wells, front ends, etc. I'm sure it would have to be periodically replaced but it might save the paint. Even a few layers of heavy duty clear packing tape might do the trick.
Some sort of thick, adhesive tape might also work. Something thin enough that it doesn't make the tailgate stick out too much. |
06-25-2019, 03:29 PM | #10 |
Re: Tailgate bumper
Minimal searching found "friction reduction tape". Perhaps a couple short strips where your gate first makes contact would do the trick. I wonder if it's available in clear?
https://www.rockler.com/nylo-tape-fr...yABEgItkfD_BwE |
06-25-2019, 03:47 PM | #11 | |
It's Better With Nitro
Re: Tailgate bumper
If you're not using the original tailgate chain and hook to secure the tailgate, what are you using to lock the tailgate in the up or down positions? I ask because I use a hidden latch system with pins that lock the tailgate in the up position with no contact with the bedsides and no movement.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
06-25-2019, 04:47 PM | #12 | |
Re: Tailgate bumper
The issue is that 60-66 tailgates in the fully up position rest on the metal of the stake pockets. I don't want this as it will ware paint. 67-72 have a nice recessed rubber bumper to stop the tailgate in its full up position. I want the tailgate to fit flush but have enough room to fit a rubber bumper. Short of cutting and welding the stake pocket the height of the tailgate, I am not sure what to do. I am sure someone has run into this before? |
06-25-2019, 05:17 PM | #13 |
Re: Tailgate bumper
Maybe a couple of pieces of some medium density foam tape that will almost fully collapse when the gate is shut?
06-26-2019, 01:53 PM | #14 | |
Re: Tailgate bumper
My tailgate with the hidden pin latches do not contact the bedside stake pockets. The mount for the pin receiver from Mar-K is very accurate in spacing the tailgate so there is no metal-to-metal contact. In fact, there is enough room for my tailgate guard.
06-26-2019, 08:46 PM | #15 |
Re: Tailgate bumper
That is good news. Hard to tell from your pictures, but how flush is your tailgate with the rear of the box sides? Did you do your paint? Did you do anything special to get the tailgate flush?
06-27-2019, 09:21 AM | #16 |
Re: Tailgate bumper
It fits better than the orginal...
07-02-2019, 12:24 AM | #17 |
Re: Tailgate bumper
Looks nice
dont want to hear excuses, i want to hear solution(s) |
