Old 07-01-2019, 10:12 PM   #1
Jl8806
Anyone swapped all factory x members for aftermarket tubular?
I keep pulling out factory crossmembers and replacing them with aftermarket ones and I'm kinda wanting to just go ahead and do the rest of them but I'm kind of concerned that maybe it might be weaker than the factory one, for instance the factory shock x member is riveted on the top and bottom and the aftermarket ones I've looked at just bolt to the bottom. I'd like to take out the flat curved one under the core support but it seems a lot stouter than the one that bolts in with the core support mounts.
Jl8806 is offline   Reply With Quote
Old 07-02-2019, 02:50 PM   #2
Jl8806
Re: Anyone swapped all factory x members for aftermarket tubular?
Anyone?
Old 07-02-2019, 11:22 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Not sure why you'd want to change the cross members out, unless they were rusted beyond repair. I will say that the rivets provide tons (literally) more force on the parts held together than bolts do. If I ever had to change one out, I'd find a way to have them riveted again (or maybe even welded, if I couldn't rivet them). You'll certainly see differing opinions, but this one is all mine.
~Steven
Simi Valley, CA
Old 07-07-2019, 08:58 AM   #4
Jl8806
I'm going to have to completely disassemble the frame the get all the rust, so now I don't know what to do, I guess I'll use grade 8 bolts, loc tite, and maybe a few tack welds...
Old 07-07-2019, 09:14 AM   #5
Grumpy old man
Grumpy old man's Avatar
Where are you in KY ? I have some frames that look a LOT better than what your working with .
Old 07-07-2019, 09:15 AM   #6
CG
BlahBlahBlah
It’s been done tons of times here on the board. Use the google search bar at the top of the page. Make sure you click the 67-72 button. You may have to get creative on your search parameters
Old 07-07-2019, 09:22 AM   #7
Grumpy old man
titled long bed frame .
Old 07-07-2019, 09:44 AM   #8
Jl8806
My frame is not that bad I just hate to go thru all this trouble and still know there's rust in behind the body mounts and cross members that will start creeping out...
And it's an original short bed frame. Do you have any of those for sale?
Old 07-07-2019, 09:54 AM   #9
Grumpy old man
You posted this picture a couple weeks ago . That's a bent frame . you may want to X measure to see just how much it's bent
Old 07-07-2019, 10:25 AM   #10
Jl8806
That's all being took care of and I've done checked, it's not bent. Maybe in that one spot there but I'm really not sure what's happened with that support brace. Getting rid of all rust is my main concern at this point
