Old 07-07-2019, 11:54 PM   #1
Angrywood
Is this rear stock?
Can someone please tell me if this rear end is stock for a 62 c10? I’m looking at putting 2” drop coils and 2” drop blocks but dont want to get started if im not sure what I’ve dealing with. I know the air shocks are not stock. But with that being said do you need both coils and shocks? Thanks
Angrywood is offline   Reply With Quote
Old 07-08-2019, 04:03 AM   #2
BabyBlue64
Re: Is this rear stock?
This rear end is not original for a '62. This is a 12 bolt from '65 and later. But that's no problem when you want to install dropcoils.
BabyBlue64 is offline   Reply With Quote
Old 07-08-2019, 10:16 AM   #3
LVPhotos
LVPhotos's Avatar
The 62 had longer panhard bar mounted to axle tube. And was a round pumpkin. The arm mounts would be wider than the mounts that are stock to rear or leaf.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 07-08-2019, 12:01 PM   #4
SkinnyG
SkinnyG's Avatar
The u-bolt setup looks.... strange.
The u-bolts are supposed to go through the center of the trailing arm. I know the 60-62 trailing arms are spaced wider, which is probably why there's another U-bolt on either side. Looks like there is some sort of adapter plate there to fit the later axle.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 07-08-2019, 12:05 PM   #5
Angrywood
If I buy shocks, coils and drop blocks for a 65....i should be good with an easy swap? And also buy a 65 trac bar?
Old 07-08-2019, 02:55 PM   #6
Android04
Android04's Avatar
Drop blocks for a 65 won't work because of the U-Bolt setup. Shock setup is also different from 62 - 65 so I would look at the lengths of both of them and go from there. Coils and track bar should be just fine. If you're lowering it I would consider an adjustable trac bar.
Good Luck
Android04 is offline   Reply With Quote
Old 07-08-2019, 06:42 PM   #7
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I put a 65 12-bolt on my 62 frame. Because of the difference in spread, I welded new saddles next to the existing.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 07-08-2019, 11:11 PM   #8
Captainfab
60-66 Nut
The first thing I would do is remove that whole cobbled mess with the u-bolts and shims.Then weld on some new trailing arm mounts in the correct location for your trailing arms. Then you can change the springs and add your drop blocks. The springs and blocks for a '62 are no different than for a '65. You will want the dropped panhard bar assembly for a '60-'62.
Old 07-10-2019, 07:25 PM   #9
demian5
demian5's Avatar
Looks like that was done instead of putting mounts on the axle. Its so easy to put a later axle in a 60-62, you just weld new saddles right outside of the existing ones...
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 07-11-2019, 06:43 PM   #10
Angrywood
Thanks for the input. Luckily for me I’m very very limited in my knowledge of this stuff. So I think I may need to find a shop to do it. Any one in SoCal know of a good shop to use?
