07-09-2019, 07:04 PM | #1 |
K/5 Tahoe build thread
OK - I'm officially starting my build thread. I recently picked up a 71 Blazer and have plans to put the body on the frame of my '99 Tahoe. I don't plan on starting the work until next month, but I read thru a bunch of build threads over lunch today and am getting the itch to start!
Step 1 is to put a '71 front clip on it Step 2 is new rockers and bed rails Step 3 is parting out the Tahoe and shortening the frame Step 4 - body swap Step 5 - paint Sounds easy enough, right? Here are the 'before' pics:
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958 |
07-09-2019, 07:34 PM | #2 |
Re: K/5 Tahoe build thread
Personally I would keep the 1968 front clip?
I have been toying with the idea of swapping a blazer onto a trailblazer SS frame but haven't really looked into if it is doable?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
07-09-2019, 08:21 PM | #3 |
Of course anything is possible with enough time and money! I believe the Trailblazer has about 2.5" narrower tread width, so that would be a bit more of a challenge.
The Tahoe and Blazer have the same tread width, but the 4 door Tahoe has a 13.5" longer wheelbase, so the frame will have to be shortened. And I'm pretty sure the body mounts will not line up either, so I'll have to fab up mounts to mate with the Blazer tub.
07-10-2019, 09:00 PM | #4 |
Carpe manana
I’m in. Is Waterloo that tropical looking year round?
07-16-2019, 04:05 PM | #5 |
LOL - I'm still using the CL pics (found it in FL).
I was just up in Black River Falls last weekend - met member 'leisure67' to pick up a right side fender. Great guy! Lots of toys!! Will have to find another reason soon to run back up there and say hi!
07-17-2019, 07:34 AM | #6 |
Carpe manana
Sounds good. Definitely pay a visit if you venture this way.
08-03-2019, 10:03 PM | #7 |
Start of August, start working on the Blazer transformation. Swapped the tailgate today, but had to straighten the rust free one...
Filled the upper trim holes in one of the fenders, and cut out the rust on the bottom of the other...
08-05-2019, 12:37 PM | #8 |
At the risk of criticism, here's a pic of the patch panel welded in (and the area on the Blazer which donated it!). I promise my welding skills will improve as the project evolves!
08-07-2019, 12:58 PM | #9 |
One fender down. Gotta finish the other fender and then I can start the swap. Going to run it in primer while I take on the rockers, doors, and quarters over the winter...
08-21-2019, 07:20 PM | #10 |
Progress pics from last weekend:
08-21-2019, 07:56 PM | #11 |
It's looking better already!
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
08-21-2019, 08:14 PM | #12 |
Carpe manana
Quick work. Big improvement imo.
12-11-2019, 01:48 PM | #13 |
Removed and gutted the doors - passenger side bottom is decent and only a couple minor dents to repair.
Driver door bottom is more swiss cheese - may have to look and see if I have another door in better shape - otherwise it's cut/fab a patch panel out of the 67 hood.
01-25-2020, 09:32 PM | #14 |
Finally found some time to spend with the Blazer again. I addressed the rusty bed rail on the passenger side. I got the rear piece located, next will be to cut/replace the front half as well. The donor bed rails came off the original '72 K20 box. I just received the inner/outer rockers from GMC Paul's too, so more fun ahead!!
02-03-2020, 01:20 PM | #15 |
Finished getting the bedrail in place and started on the passenger rocker:
02-03-2020, 09:33 PM | #16 |
In the post that started with "at the risk of criticism" the spatter marks in the paint looks as if you're using a flux core welder. Is that the case and if so does it have the option to hook up gas?
Not to criticize but it looks like you are getting a lot of burn through on your welds. The proper setup can fix a lot of that. Flux core typically burns too hot for butt welding patch panels (not impossible but damn hard especially for a beginner). If your machine is capable of it I recommend running 75/25 and .023 wire. If you're stuck with flux core I recommend getting one of the cheap pneumatic flanger tools ($35 from harbor freight) and lap welding your patches. If I'm wrong and you're not using flux core let me know what you're working with and the settings. I'm no pro but I might be able to recommend setting and share some tips to get you a better result. |
02-04-2020, 11:53 AM | #17 |
yes - I'm using a flux core setup with no gas. I've been playing around with the settings to get better quality - making a bit of progress...
I'm certainly open to suggestions/recommendations - been quite a while since I've been around welders and even when I was I still wasn't good!
02-04-2020, 12:47 PM | #18 |
One thing to remember that some people miss is to reverse the polarity of the welder if you go from fluxcore to gas.
I used fluxcore on my floor pans (I had a lot of it so why not???) and switched over to gas and .023 wire for the outer sheetmetal. Great work so far, Rg
02-04-2020, 02:06 PM | #19 |
Glad to see you're making progress Paul!
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
02-04-2020, 02:26 PM | #20 |
On flux core for sheetmetal I’ve found the best size to be .030. And make sure your metal is clean. Other than that all normal welding practices
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
02-04-2020, 02:38 PM | #21 |
Are you using .030 or .035 wire? If .035 you should switch to .030.
Even with .030 butts will be a struggle especially if there are gaps during fit up. If I were going to use flux core I'd try one of the two types of flange methods shown below. Manual and pneumatic tools are available for each and are pretty cheap. The additional metal in the weld should eliminate most of the burn through. The lap type is the most forgiving. The type that rolls the edge 45 degrees provides a nicer repair IMO as there is no lapped joint to hold dirt and moisture, however you'll have to have your fit up near perfect. |
05-01-2020, 03:32 PM | #22 |
3 months since my last update and I’ve gotten a bit more done (it’s been a pretty busy winter!). From the outside it looks pretty good – still have a bit of patch work to do on the inside. At least I can get out and enjoy this warmer weather (took it out for an hour trip yesterday!). The Blazer will remain in this condition until it’s ready to go on the ’99 chassis.
Next step – tear into the ’99 – I know it’s a Yukon, but I’m calling it a Tahoe to stay in the Chevy family. On the agenda is removing the body, shortening the frame 13.5”, and welding in new body mounts. Along with that is going thru the entire wiring harness to connect the ’71 features to the correct wires! I won’t get serious about it until this fall/winter since I want to enjoy the Blazer with the family this summer. I know there are some questioning this project and say I should just invest/improve the ’71, but here’s the deal: Life events made me choose to sell my ’72 K20 last year and back in 2006 I sold my ’72 Blazer that came from my grandparent’s farm due to moving and lack of garage space at the new place. This project will allow me to bring parts/memories of both of those into one vehicle. Along with that, I bought the Yukon from my uncle back in 2014 and he passed away from cancer in 2017. Using this chassis brings all of this together into one. This is truly a family affair – so along with all the memories from the past, I’m able to do something that my family can enjoy now and into the future. Enjoy the pics!
05-01-2020, 03:34 PM | #23 |
more pics:
05-01-2020, 03:36 PM | #24 |
even more pics!
05-01-2020, 03:37 PM | #25 |
Here's the donor chassis & drivetrain:
