Old 07-15-2019, 06:06 PM   #1
ibinyth
18x9 front and rear?
Is it possible to run a 18x9 front and rear on a 70 c10? Likely running 275/40r18 if a 18x9 will fit what backspacing? Tried searching but couldn't find anything
Truck is currently 3/5 drop.. Bed is off as frame is a about to be notched. Will be a fleetside no tubs or bedfloor.
ibinyth is offline   Reply With Quote
Old 07-15-2019, 06:28 PM   #2
MySons68C20
MySons68C20's Avatar
Re: 18x9 front and rear?
18" X 9.5" 5.25 backspace. Rear tires are 275/55 R18. Front tires are 255/55R18
2.5" drop spindle front with a 4" drop in the back.
MySons68C20 is offline   Reply With Quote
Old 07-15-2019, 06:29 PM   #3
ibinyth
Are your front wheel specs the same as the rear? 18x9.5
Old 07-15-2019, 06:34 PM   #4
MySons68C20
Yes, they are the same. I went with a slightly smaller front tire because it did rub on the inner fender a touch. The only thing close on the front are the brake lines at full lock. I wrapped those with wiring loom just in case but no issues.
The wheels are the Rambler U111 if that helps. Link below....scroll down a bit and click on the 18" tab
http://us-mags.com/rambler-u111-w-6133.htm
Old 07-16-2019, 03:51 PM   #5
68Stepbed
68Stepbed's Avatar
I'm also on the US Mags Ramblers in 18x9.5. These photos are with 285/40/18 tires.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-16-2019, 04:15 PM   #6
ibinyth
I plan on running a set of 18x9 with 275/40r18s front and rear with a 5 backspacing both front and rear as that's my only option for these wheels. Think I'd need a spacer on the rear to get it closer to the fender or do you think it'd look fine?
Old 07-18-2019, 09:13 AM   #7
68Stepbed
68Stepbed's Avatar
Spacers won't be required, but the fleetside has rather large wheeltubs, so you may want to space them a bit for a desired look.
Matt
