Re: Dapper Lighting - Projector Headlights
So, similar or improved light output vs. relays & factory lights?
Do you guys still recommend adding a relay harness for these or do they work pretty good with just the factory wiring? The pictures in your other thread looked killer, just wasn't sure if that was with upgraded wiring or just the factory stuff...
#5 | |
You can always take a volt meter and see what your stock plug is putting out. That'll tell you whether to get a relay harness or not. |
![]() Join Date: Jun 2017
looking at the classic v2. same lights in my '49. But I'm not sure I have the depth before I get into the battery trays which are behind each light.
1949 Chevy 3100 P/U http://67-72chevytrucks.com/vboard/s...d.php?t=302780 1976 GMC Sierra Classic C35 CCSB http://67-72chevytrucks.com/vboard/s...25#post8188825 |
Ah gotcha. If you can snag a measurement from the tabs back we can narrow down which ones would probably work. We also have a few cool tricks if it's less than 1/2" off.
#8 | |
I really want to run them. They transformed my '49, and I already had E46 projectors in a retrofit before.
