Old 07-16-2019, 12:57 AM   #26
Getter-Done
Getter-Done's Avatar
Re: tongue and grove for truck bed floor?
Sounds like a good plan.
I was watching this video in the link
below today.
I thought about your project.
Fast forward to about 11:30.
He makes a very good suggestion to Stain the bottom and sides.
He shows the example of what it will do if not protected.
Link: https://www.youtube.com/watch?v=EiN9woZqbIg
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 07-16-2019, 01:08 AM   #27
slepysal
slepysal's Avatar
thanks for the link!!!!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 07-16-2019, 10:36 AM   #28
jayoldschool
Moderator
Do yourself a huge favour and take the bed off. Much easier that way.
jayoldschool is offline   Reply With Quote
Old 07-17-2019, 11:36 AM   #29
slepysal
slepysal's Avatar
So far I haven't run into any issues working with the bed on (probably just jinxed myself)
Old 07-17-2019, 05:57 PM   #30
jayoldschool
Moderator
Oh, you can do it with the bed on. It's just easier with it off. First one, I did flat, on stands. Sliding underneath about a hundred time for nuts. On the second one, I stood the bed upright. It is MUCH easier to do it that way.
First one:
Second one:
Old 07-18-2019, 01:24 AM   #31
slepysal
slepysal's Avatar
Great tip!
Old 07-21-2019, 02:01 PM   #32
slepysal
slepysal's Avatar
Slow progress .... Made a template to trim the board that goes around the wheel well,and routed it out . Too bad the holes didn't line up on the boards and cross sills. I will make some plugs and fill them.
Name:  1st boards.jpg
Old 08-25-2019, 11:27 PM   #33
slepysal
slepysal's Avatar
Very S L O W progress due to a hectic schedule and a long honey do list.
Old ply wood is out ! Planks were trimmed and rabbet cut down to 3/4 to fit under bed and cut to fit around and under wheel wells. still need to sand and finish the wood.
On a plus side I picked up a complete set of Stainless bed strip off of Long bed fleet minus hardware for.......50.00!
I will post pics tomorrow stay tuned
Old 08-26-2019, 07:14 AM   #34
Getter-Done
At least you got your priorities in order.
Job, Honey Do list and then truck.
Nice score on the trim.
84 Chevy K-20
Old 09-10-2019, 09:31 PM   #35
slepysal
slepysal's Avatar
Some updates on install. boards are in,still have to seal or stain.
Not sure which way to go on the 3" center board I was going to put one strip straight down the middle or maybe two strips on either side of it.
Old 09-10-2019, 09:34 PM   #36
slepysal
slepysal's Avatar
and yes I still have to plug all the holes !!!
Old 09-10-2019, 10:43 PM   #37
Getter-Done
Great Progress.
Looking good
84 Chevy K-20
Old 09-11-2019, 12:07 AM   #38
cwcarpenter98
cwcarpenter98's Avatar
That's going to look great when finished. I think having a strip down each side of the middle would look good, and it would cover the gaps
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 09-11-2019, 08:22 AM   #39
67C10Step
67C10Step's Avatar
When I read the title of this thread my first reaction was "NOOOOOOO" because just a few weeks ago I removed a tongue and groove wood floor from my 67 stepside bed. Some PO decided tongue and groove with 50 carriage bolts was a good idea. Yes 50, I counted them. After careful consideration I decided the 4-1/2" grinder and an air hammer were the proper tools for the job. The cross sills have way too many holes in them now but they seem solid.
As to the work I have seen here I actually like it a lot. The color variation looks great and should make a nice looking and unique floor when complete. Look forward to seeing it.
My bed is now in pieces as the front panel and rear sill were too rusty to save. I'll strip the bed sides this fall/winter and try to get all the parts to put back together by spring. Hopefully, maybe. You guys know how these projects go.
67C10Step is offline   Reply With Quote
Old 09-11-2019, 10:06 AM   #40
jayoldschool
Moderator
Looks good. Leave the holes, no need to plug them.
Old 09-11-2019, 11:57 AM   #41
davee60
Looks great!
I guess I'm too late with this suggestion, but if anyone else is interested, I used Trex in the bed of my Suburban. Super durable and comes in different wood grains. I used the "fascia board" size, which is thinner but wider than the standard Trex deck boards. I think it could be a great choice for an open bed since it is more weather durable than wood.
Dave
1966 K10 Suburban
davee60 is offline   Reply With Quote
Old 09-11-2019, 03:59 PM   #42
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by davee60 View Post
Looks great!
How much total for the trex boards?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-11-2019, 04:31 PM   #43
davee60
Sorry, I don't remember the exact cost, but I didn't think it was unreasonable. I had to special order the fascia boards from the "warehouse hardware store", and if I remember correctly they come in 12 foot lengths. Check the Trex website for the exact specs and the various wood grains that are available. Hope this helps.
Dave
1966 K10 Suburban
Old 09-11-2019, 09:14 PM   #44
jayoldschool
Moderator
I used 10' Trex fascia boards. They go on sale.
Old 09-11-2019, 09:41 PM   #45
slepysal
slepysal's Avatar
Thanks to all for the kind words. Hopefully I will be able to finish next weekend. This weekend is shot due to a wedding out of town
