Originally Posted by _Ogre
tf trucks take this type shock front and rear, they come with rubber on them
if you've modified your truck height, download the monroe catalog to see all the options available
jack the truck up to see the extended length and then figure the lower height by figuring out the bumpstop height
then look at the monroe catalog to see what shock you need
i flipped my axle on stock springs with stock brackets, found my shocks this way
![](https://shop.advanceautoparts.com/wcsstore/CVWEB/staticproductimage//50/large/19711083_mon_37246_pri_larg.jpg)
Ok thank you. I didn’t change my height. Kept it stock except changing the rearend to a limited slip out of a 76 trans am. Which isn’t changing the height any
