Old 07-22-2019, 12:55 AM   #1
Aus69c20
Aus69c20's Avatar
Sway bar mounting flip
I’m sure I’m not the first to think of this. But I thought I’d share the idea.
After lowering my c20 the original sway bar didn’t align nicely with the mounts in the control arms.
What I did was remount the sway bar on top of the original stand off brackets.
I had to knock out one rivet at the front of one bracket then I passed the sway bar through the other side and bent the bracket down far enough to push the sway bar through. Then I bolted down the sway bar and put in a grade 8 bolt to replace the rivet I knocked out.
This saved me buying the low profile brackets offered and seemed to me a lot less work. The bar aligns perfectly now.
This is on a 69 C20 so I’m unsure if the C10 bracket is any different and this is a stock sway bar. But worth a look if you’ve lowered your truck.
I’ve attached a few pics. The original mounting, the flipped mounting and of course the truck.
John
69 c20, 396, th400, dana60, ps, ac
Aus69c20 is offline   Reply With Quote
Old 07-22-2019, 12:55 AM   #2
Aus69c20
Aus69c20's Avatar
Re: Sway bar mounting flip
Arghhhhh up side down pics
John
Old 07-22-2019, 01:08 AM   #3
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
That's exactly how I did mine! Works great on the lowered trucks!
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 07-22-2019, 06:48 AM   #4
Aus69c20
Aus69c20's Avatar
Yeah figured it would have been done before. But that didn’t stop me feeling pretty clever.
John
Old 07-22-2019, 07:26 AM   #5
Mike C
Mike C's Avatar
Ingenious. Nice work.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 07-22-2019, 08:10 AM   #6
Grumpy old man
Grumpy old man's Avatar
All the pictures you guys from down under post are upside down on our computers .
Old 07-22-2019, 08:13 AM   #7
Katrina/10
Katrina/10's Avatar
That's a great idea, first time I've seen it.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 07-22-2019, 06:39 PM   #8
bill3rail
bill3rail's Avatar
Does not work on all OS's.
• Ctrl+Alt+↓ - Flip the screen upside down.
• Ctrl+Alt+→ - Rotate the screen 90° to the right.
• Ctrl+Alt+← - Rotate the screen 90° to the left.
• Ctrl+Alt+↑ - Return the screen to the standard orientation.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 07-22-2019, 07:09 PM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
Knock the bracket off. And bolt the bushing clamp to the rail.
Rare to see an un bent bracket.
Old 07-22-2019, 08:08 PM   #10
Aus69c20
Aus69c20's Avatar
It took a while for the truck to get used to it’s new orientation.
Upside down and on the wrong side of the road.
John
Old 07-22-2019, 08:20 PM   #11
Aus69c20
Aus69c20's Avatar
I did consider knocking off the bracket, but took the easy way out.
The whole trucks in great condition. I don’t think it was ever used for work.
Rockers, cab corners are original and rust free. Tailgates straight, beds in great condition and the paint is mostly from 1969.
If it was a shortbed c10 I’d be sitting on a goldmine.
John
Old 07-23-2019, 03:00 AM   #12
Richard
fixed for you
Richard
Old 07-23-2019, 06:44 AM   #13
Aus69c20
Aus69c20's Avatar
Thanks Richard
John
Old 07-23-2019, 12:46 PM   #14
michael bustamante
michael bustamante's Avatar
i did that to mine too.... more clearance
1967custom
michael bustamante is offline   Reply With Quote
Old 07-23-2019, 12:47 PM   #15
michael bustamante
did not know this!!! thanks !!
1967custom
