Old 07-24-2019, 10:57 AM   #1
andrewpclayton
andrewpclayton's Avatar
Front blinkers not working
Hi everyone..
I have a new to me column from another 69 in my truck after the auto trans conversion. All is working except the front marker turn signal lights. (Don’t have bulbs in the sides as I’m going to fill those holes)
With headlights on, the lights come on solid, but with headlights on or off they do not blink with blinker.
Previously the left side only worked with right side coming on solid only. Then I tried my hazard lights, nothing worked and the blinkers no longer worked on left.
So I got a brand new flasher, and now I’m here with only rear blinkers. 1157 bulbs.
The rear both work fine. What should I check first?
1977 SWB (c20 conversion) SBC350
Springfield Oregon
Instagram: @nevernotchevy
andrewpclayton is offline   Reply With Quote
Old 07-24-2019, 04:15 PM   #2
bozly
Re: Front blinkers not working
put working bulbs in your side marker lights up front. I had weird issues with my blinker and once I made sure the blinker grounds were good and put bulbs in the side markers I have not had any of the issues I previously had (which were similar to yours).
bozly is offline   Reply With Quote
Old 07-24-2019, 04:17 PM   #3
andrewpclayton
I will give that a shot thanks!
Springfield Oregon
Old 07-24-2019, 07:55 PM   #4
LuckyScott
LuckyScott's Avatar
Make sure they are grounded
LuckyScott is offline   Reply With Quote
Old 07-25-2019, 01:27 AM   #5
Sheepdip
Sheepdip's Avatar
As stated check and verify grounds.
Sheepdip is offline   Reply With Quote
Old 07-25-2019, 07:17 AM   #6
rpmerf
rpmerf's Avatar
Given that the running lights work, I think it is unlikely that it is a grounding issue. Side markers should just be running lights, not turn signals, so I do not think they would effect turn signals. I could be wrong, and these are easy things worth testing.
http://outintheshop.com/faq/wiring/w...s/image002.jpg
http://outintheshop.com/faq/wiring/w...s/image003.jpg
According to the diagram, it appears the indicators on the dash are connected to the front bulbs, right after the turn signal switch. I believe this means that if your dash indicators are NOT working, but your rears are flashing correctly, then the switch is to blame. If the indicators ARE working, then the problem is between the switch connector and the light.
I would get the test light out and start following it from one end to the other. Test it at the bulb socket. Test it at the connector for the lights above the column. If the connector above the column looks good, but there is no voltage at the sockets, inspect the bulkhead on the firewall.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
