07-24-2019, 12:19 PM | #1 |
Rear End Swap
I have a 1967 C10 with an open rear differential. I wanted to swap to a posi rear end. I found a 1990 Silverado with a G80 rear end the question I have is can I take the chunk out of the 1990 Silverado and put in my 67 with changing the whole rear end?
07-24-2019, 12:36 PM | #2 |
Re: Rear End Swap
No. The 12 bolt (8.875" gear) parts do not interchange with a later 8.5" gear
07-24-2019, 12:39 PM | #3 |
Re: Rear End Swap
Thanks. Any advice on how to swap to a posi without breaking the bank?
07-24-2019, 12:47 PM | #4 |
Re: Rear End Swap
find an older (73-84) rear end with a posi like a 14bolt, may have to weld a new shock mount, but the rest should fit.
07-24-2019, 01:15 PM | #5 |
Re: Rear End Swap
Forget the G80 crap, suck it up, save some money and put an Auburn in it. You'll be ahead in the long run
07-24-2019, 02:32 PM | #6 |
All about them K’s
Re: Rear End Swap
Exactly right, the g80 has the nickname gov bomb for a reason.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
07-25-2019, 02:36 AM | #7 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Rear End Swap
With all due respect, Totally BS! No C/10 EVER came out of the factory with a G80! Period! Your 1/2 ton 67 most likely has a 12-bolt. The G80's were not only reliable but second only to the "Detroit Locker" that were ONLY available in the 3/4 & 1 ton 14-bolt axles so get it right! The 1-ton G80's were impervious compared to the "1//2 ton Gov Locks!" Know WTF your talking about before you stick your Chinese made size 10's in your mouths! The 69 C10's had factory 12-bolts, 12T's as opposed to the car 12p's (T=Trucks P=Passenger cars) Now on to the answer...Buy a 12T Eaton Posi, install your current gear set, and enjoy one of history's greatest mechanical differential milestones ever...The 12-bolt truck Posi! No cheap way out! 470$ for a Legend! All that G80 talk is BS because first of all, you don't have one! Second of all, most the schmo's that said they're no good? Never had one! "Just Sayin!"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
07-25-2019, 06:33 AM | #8 |
Re: Rear End Swap
07-25-2019, 07:24 AM | #9 |
Re: Rear End Swap
My 95 GMC K2500 has it's second G80 in it the first one lasted over 200,000 miles of working ,Hauling heavy loads and pulling trailers all over the south east , It finally let go while I was delivering a short bed from eastern NC to another member in Nashville . I limped it home and I already had another rebuilt carrier sitting in my garage because I knew it was on it's way out but I thought I could get one more trip out of it , Nope .
The local parts houses wanted $750.00 + for the G80 ,I found one on Ebay for $299.00 and it's been in there for 5 years now . 6 years ago I was buying clean short beds for $4-500.00
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 07-25-2019 at 07:45 AM. |
07-25-2019, 08:55 AM | #10 | |
Re: Rear End Swap
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
07-25-2019, 11:41 AM | #11 | |
Re: Rear End Swap
07-25-2019, 11:52 AM | #12 |
Re: Rear End Swap
the 67 chevy does have coils. but leafs were an option.
if he were to go with a 73 square body rear, of course he would have to weld on new mount plates where the trailing arms attatch and cut off the shock mounts as the lower shock mounts are plates under the rear end mounts. also he would have a 5 bolt in the rear and 6 in the front till he does a disk brake swap. this is the most common thing to do. 67-70 rear ends with posi are out there for sale if you are patient and look or do a WTB on here if youre a paid subscriber. Grumpy probably has about 4 or five stashed in his sheds! LOL. If you don't want to convert to disk yet I would look for a 63(?)-70 trailing arm posi rear end as its a direct bolt in
1967custom |
07-25-2019, 01:11 PM | #13 |
Re: Rear End Swap
[QUOTE= Grumpy probably has about 4 or five stashed in his sheds! LOL.
I have a few stashed away No, They are not for sale .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
07-25-2019, 03:19 PM | #14 |
Re: Rear End Swap
[quote=Grumpy old man;8564773][QUOTE= Grumpy probably has about 4 or five stashed in his sheds! LOL.
I have a few stashed away No, They are not for sale . [/quote] I knew it! youre a hoarder like me!
1967custom |
07-25-2019, 07:06 PM | #15 | |
All about them K’s
Re: Rear End Swap
07-25-2019, 09:29 PM | #16 |
Re: Rear End Swap
I'd like to think so, but I'm guessing not.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
