06-05-2004, 03:00 AM | #1 |
HEI Fit In A 4X4
The 350 in a 4X4 is even closer to the firewall than a 2 wheel drive. Does anyone know for sure if an HEI will fit in a 4X4? Thanks, Joe Bob.
06-05-2004, 03:08 AM | #2 |
Member since 2000
Yes, my 350 is sitting in the 6cyc positions and the HEI fits just right. You got to have the cap and rotor off but it fits.
06-05-2004, 04:37 AM | #3 |
I gotta 350 w/HEI set up in my '71 GMC Jimmy -- like a K/5 but GMC's paperwork calls it a "K/1500." Third engine --at least as I know-- but it came from the factory w/ a 350. So I hope it's the stock set up. It's a tight fit, but I didn't even have to ding on the central firewall. Distributor install is a 3-step process, however, first the candlestick proper, then rotor, then cap, then wires. You gotta layer it in gradually. With the old points set up, you could leave the plugwires all thatched together and just snap the cap on in 2 places. The HEI uses 4 screws that you need a 90 degree screwdriver to set. Tough reach until you get the right tool set up.
06-05-2004, 06:23 AM | #4 |
HEI fit
Summit has better than stock HEI units that are smaller in dia. and easier to work with in the tight areas if you have the money to buy a new dist.
06-05-2004, 06:59 AM | #5 |
Next!
My 72 K10, 350, Auto and 72 K25 350, 4M both have been converted to HEI, stock motor mounts, etc, no problem!
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
06-05-2004, 11:23 AM | #6 |
BOTH OF MY 71 & 72 BLAZERS HAVE STOCK G.M. HEIs IN THEM, & ROOM IS NOT AN ISSUE. (QUOTE) Summit has better than stock HEI units that are smaller in dia. and easier to work with in the tight areas if you have the money to buy a new dist. (QUOTE) THE NICE THING ABOUT GM HEIs IS THAT YOU CAN GET ONE IN ANY TOWN IN THE USA IF YOURS QUITS. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
06-05-2004, 09:07 PM | #7 |
PROJECT 7DEUCE
Yep got one in my k-5 blazer..
06-05-2004, 10:38 PM | #8 |
Thanks guys!
