Old 09-26-2006, 09:14 PM   #1
LockDoc
The Older Generation
LockDoc's Avatar
Heater Cable Removal Tip
I did some searching but didn't come up with a post on this. Sorry if it has already been covered….
Here's how I removed the keepers that hold the heater cables onto the control arms without breaking them.
The first picture is the tool I used to remove the keepers. It is one of the small pick tools (approx. 4" long) The small hook is easy to get under the keeper and work it up off of the post. Take your time & work your way around the inside of the keeper and push it up off the post. Make sure that the tool is between the keeper and the cable end as shown in the last picture. A drop of lube on them will help.
LockDoc
Leon
Old 07-29-2019, 07:25 AM   #2
bigmac73
bigmac73's Avatar
Re: Heater Cable Removal Tip
well I removed mine yesterday as i was tearing down the cab for paint, and i snapped a couple of the retainers in half.
Where can i find some decent replacement retainers??
I realize this is an older post but you never know...
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 07-29-2019, 07:47 AM   #3
67GMC
67GMC's Avatar
I was just at Ace Hardware over the weekend looking for something similar (a thin thread on nut). I'd check your local hardware store in the nut & bolt section. Ours had several automotive trays which included some of these push on clips.
67 GMC C2500
GMC V6 4spd NP435
Dana 60 4.10 Power Lok
67GMC is offline   Reply With Quote
Old 07-29-2019, 08:13 AM   #4
bigmac73
bigmac73's Avatar
Will do Thanks
Mike
Old 07-29-2019, 09:01 AM   #5
stsalvage
Scrapper 1
stsalvage's Avatar
best off to lube them before you pick at them
stsalvage is offline   Reply With Quote
Old 07-29-2019, 10:46 PM   #6
Astro-Balls
Astro-Balls's Avatar
You can find Push Nuts here..
https://apexfasteners.com/fasteners/...treg-fasteners
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 07-29-2019, 11:27 PM   #7
LockDoc
LockDoc's Avatar
NAPA has them or can get them if you have one local to you.
LockDoc
Leon
