Old 07-29-2019, 05:30 PM   #1
kens65fb
I removed my locking gas cap with a FORK !!
When I got my 64 C10, it had a locking gas cap, but no key !!
I needed to remove the cap to pump some fuel,.
I posted my problem on this forum, but the only suggestions I received, were to remove the seat, and either remove the gas tank, or disconnect the rubber filltube.
Either way, it's not a job I wanted to tackle.
After a quick you tube search, I came across a video that showed someone removing the exact same gas cap, with a FORK !!!
Anyway I tried, it and it worked in under 30 seconds.
Here is a link to the video
https://www.youtube.com/watch?v=RKbv5Xe4ELI
kens65fb is offline   Reply With Quote
Old 07-29-2019, 07:23 PM   #2
kens65fb
Re: I removed my locking gas cap with a FORK !!
Wow that was amazing, good to know.
Old 07-29-2019, 07:35 PM   #3
AcampoDave
AcampoDave's Avatar
Yeah, I used to have one of those too. Eventually it go to where I didn't need a key to remove it. It was like a standard cap except you had to know how to twist it just right.
AcampoDave is offline   Reply With Quote
Old 07-30-2019, 12:17 AM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Yep, my 66 locking cap doesn't have a key. Just twist and pull and it comes out.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
