Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 07-30-2019, 07:53 PM   #16
sweetk30
sweetk30's Avatar
Re: 1969 C50 4x4 Axle Swap?
well 2 of you guys were tering up others threads at the same time asking the same basics so i got mixed up on who was who .
so here ya go from the other thread i posted in .
1ton down is setup for 2.75" wide stock leafs . aftermarket like lift kits go 2.5" you cant cut in the the housing for 3" wide unless you do a home brew u-bolt conversion as you will loose the 2 bolt holes for the spring plate .
the width for a dana 60 front is 32" center to center .
the 1ton rear for a 14ff is 40.5" center to center and 2.5" wide springs .
the rear can be worked around a bit but the front has the pass side spring mount cast in to the diff housing .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
