07-30-2019, 05:36 PM | #1 |
fire wall pads
So i am stripping my cab for the paint shop, the old firewall pads just fell apart.
So do i need to put new ones back in ?? who is running with and with out them? Pros and cons??
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
07-30-2019, 05:40 PM | #2 |
Re: fire wall pads
I’m also wondering about this. But to go a step further, could sound deadener (dynomat) replace the firewall pad? Thanks
07-30-2019, 05:52 PM | #3 |
Re: fire wall pads
I don't know how much difference they make. From what I can tell, they're mostly for thermal insulation and maybe a little bit of sound deadening. We didn't install them on my dad's 64 - we just put on generic dynamat and it's not too loud. I've already welded shut the holes for the attachment of that pad on my cab, it's just cleaner that way and I hate messing with that material when I'm under the dash working on something.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
07-30-2019, 07:27 PM | #4 |
Re: fire wall pads
I used rattle trap, instead of dynomat. About the same, also added close celled foam, from Low Buck Rod....it's nice, and not bubble wrap....Mine went almost all the way up under the dash, then piece of vinyl from long ago, instead of the cardboard and jute....I think it was called tarkit....Then carpet.
07-30-2019, 09:01 PM | #5 |
landarts
Re: fire wall pads
I got mine from LMC truck, there are three separate sections about $30 each section. Here is the link to page 109 top right corner. http://www.lmctruck.com/icatalog/CB/full.aspx?page=109
Super Cheyenne aka the "Devil Cowboy" 71 K20 Idaho Edition 69 K10 from the Field 68 Second Chance Fix and Sale 72 GMC 3/4 ton 4x4 K2500 The "Fixrupr" build thread 72 Cheyenne 1/2 ton " FIXRUPR " - daily driver 67 C20 all original paint 71 K20 Custom 4x4 (Idaho Edition) 72 K20 GMC Super Custom 4x4 72 K20 Custom Deluxe 4x4 69 K10 Custom package 4x4 (69 K10 from the field) 72 K10 Custom 71 K10 Custom 72 K20 Custom Deluxe 4x4 72 K20 Crew Cab Project 71 GMC Jimmy CST 72 Blazer 70 Blazer |
