Old 05-29-2019, 10:06 PM   #1
BCOWANWHEELS
started building my 441 heads. tips 4 ya,ll
today I started building my 441 heads and thought I,d share a couple tips I,ve learned over the years.
1. when going to screw in rocker studs and guide plates.. YOU MUST DRILL OUT THE FACTORY OVAL SHAPED HOLES FOR PUSHRODS TO 7/16. USE A NEW DRILL BIT WITH A DRILL PRESS...............AND USE CUTTING OIL GENEROUSLY........
2. WHEN REMOVING PRESS IN ROCKER ARM STUDS........... HEAT STUD BOSS BEFORE YOU START THE PULLING PROCESS.
MORE TO COME
BOB
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 05-30-2019, 05:06 PM   #2
toolboxchev
Re: started building my 441 heads. tips 4 ya,ll
I'm in, let's see your progress. I love a good rebuild with all the juicy details.
toolboxchev is offline   Reply With Quote
Old 06-09-2019, 01:34 AM   #3
BCOWANWHEELS
got pushrod holes drilled out to 7/16 also got all rocker arm studs pulled and all valves n hardware removed. now off to machine shop with em.
Old 07-10-2019, 08:39 PM   #4
BCOWANWHEELS
well finally got to work on my 441 heads, I found out I have the desired Canadian heads. yee haw............all the nhra super stockers want this head because it flows 10-15 % more than the U.S. 441 HEAD. on with the grinding
Old 07-10-2019, 10:40 PM   #5
toolboxchev
Did not know about those differences. I have a set of 441 heads on my vehicle and would love to see some casting marks that show the id marks.
I can say this, they aint super fast but they have been very durable.
Old 07-11-2019, 01:15 AM   #6
BCOWANWHEELS
Comming
Old 07-11-2019, 06:49 AM   #7
driller35
driller35's Avatar
x2 would like to see the casting marks
72 Chev Cheyenne Super SB 4x4 350,4spd,buckets, tilt,tach,am-fm,extreme tow hooks,Canadian Model Production 1 of 52 SOLD
70 Chev CST, 350 auto, PS, PB, AC, tach
driller35 is offline   Reply With Quote
Old 07-11-2019, 09:12 AM   #8
suville
suville's Avatar
in on this
suville is offline   Reply With Quote
Old 07-11-2019, 09:32 AM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
There were two designs of Fuel Injection heads- the ones with 1.94" intake and 1.50" exhaust valves, and the ones with 2.02" intake and 1.60" exhaust valves. On the 2.02/1.60 heads, the valves were extremely close together. These tended to crack in the area between the valves.
I'm guessing you have the 2.02/1.60 heads, Bob?
~Steven
Simi Valley, CA
Old 07-11-2019, 12:13 PM   #10
BCOWANWHEELS
1st thing 441,s arent fuelie heads.............. yes I,am going to large valves. Canada heads have 441 cast into them on bottom side length wise on int. port, us heads have 441 cast in width wise. there heavy castings. people say go modern alum heads but what they overlook is all the cheap import heads need work b4 install so true cost is a lot higher. nothing is better imo than gm for our use. lastly when folk say closed chamber is better by the time you open chamber up so int valve can breath its not 64cc chamber anymore. go 76cc and use .125 dome pistons to get 10-1, fine tune with deck height and gasket thickness. IMO I,AM NOT BUILDING A RACE ENG. JUST A REAL 355 / 350HP ENG.
Old 07-11-2019, 03:41 PM   #11
Steeveedee
Who Changed This?
Steeveedee's Avatar
Oh, OK.
~Steven
Simi Valley, CA
Old 07-11-2019, 05:28 PM   #12
BCOWANWHEELS
I have some real nice fuelie heads 4 sale off 327 / 300 hp engines
Old 07-13-2019, 12:02 PM   #13
BCOWANWHEELS
I,ll have some pic,s tonight 4 yall
Old 07-13-2019, 03:27 PM   #14
BCOWANWHEELS
Pic,s. Of 441 heads made in u.s.a. Note how the 441 is cast into the head cross wise on int. Port bottom. THIS HEAD HAPPENS TO ALSO BE A " X " CASTING WHICH I NEED 1 TO MAKE A SET IF ANYBODY HAS 1 FOR SALE REASONABLE, CORE IS FINE IN FACT PREFERED..
Old 07-27-2019, 07:46 PM   #15
BCOWANWHEELS
Got my dart s/r head side by side WITH my 441,S today.......boy what a difference....... The dart head has pueney intake ports when compared....i dont see how dart sells these.................
Old 07-27-2019, 07:48 PM   #16
BCOWANWHEELS
Pic,s comming
Old 07-28-2019, 07:38 PM   #17
68Gold/white
If your new heads are the 170cc intake port volume S/R heads, THOSE are awesome heads. They actually have more port volume than your 441's do. I have a set I plan to use on a SBC 400 some day.
Remember when looking at ports, it's not the size that's most important, it's the shape!!! I seldom hear on this board about them, it's all about Vortec's or aftermarket stuff. The 441's are great heads, the S/R's are even better!!!
68Gold/white is offline   Reply With Quote
Old 07-28-2019, 08:21 PM   #18
BCOWANWHEELS
a little hose cant flow as much as a large hose. I had these on a 383 and wasn't a bit impressed JMO SPECS TO COME. IMO IF YOUR INTO PERF AND WANT DART GET PRO 1,S
Old 07-31-2019, 04:29 PM   #19
BCOWANWHEELS
my buddy took some pic,s. 4 me but only 1 was barely any good. I tried guys. I,ll get more but it will be when heads are assembled.......
bob
