Old 08-01-2019, 11:38 AM   #1
tjmb1086
tjmb1086's Avatar
SPID is missing
Wanted to see if there was anyway i could find out what exactly my truck came with from the factory using the Vin # or what i needed to find that information out and see if there's someone that could make a new look alike SPID for the truck. Thanks for help guys.
tjmb1086 is offline   Reply With Quote
Old 08-01-2019, 12:14 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: SPID is missing
Outintheshop.com
Contact Jeff. He makes perfect spid labels, and you can add any option you want.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-01-2019, 12:32 PM   #3
weim55
Re: SPID is missing
If you are lucky there might be a build sheet in the seat springs or taped to the gas tank, or gas tank cardboard.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 08-01-2019, 01:25 PM   #4
Keith Seymore
Keith Seymore's Avatar
Re: SPID is missing
Information for US built and sold trucks not available through GM until 1976/77.
https://www.gmheritagecenter.com/gm-...tion-kits.html
If your truck was built in Canada, or built in the US for Canadian sale, then GM of Canada might have the original build info.
https://www.vintagevehicleservices.com/
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-01-2019, 01:53 PM   #5
tjmb1086
tjmb1086's Avatar
Re: SPID is missing
I found out that it was built in St Louis by the vin decoder and what it came with as far as the engine and transmission, just would like to know alot more.
Old 08-01-2019, 05:37 PM   #6
cypressbog
Go Pack Go!
Re: SPID is missing
Sorry, there's nothing that will help w/o the build sheet.
cypressbog is offline   Reply With Quote
Old 08-01-2019, 07:29 PM   #7
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: SPID is missing
Like others have said, you pretty well need a build sheet.
But......................if you were well familiar with the truck history, and knew what you were looking at, it's possible to build a SPID with a lot of certainty. Just as an example, if the serial number on the frame matches title/cab, the frame was built a certain way (SBC Vs BBC), and the castings numbers on your long block are consistent with the truck assembled date. Good chance what was installed in your truck is what's in it.
Requires a lot of research and experience, but you'd always have the caveat your SPID may not be accurate.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 08-01-2019, 07:41 PM   #8
tjmb1086
tjmb1086's Avatar
Re: SPID is missing
All the # on the frame and cab etc seem to match the vin # so I'd say its all original, just wanted to see if there's away that i could get a original Spid made for the truck looks like there's a guy that might be able to help me out. Thanks for all the replies and the good info you guys have given.
Old 08-01-2019, 08:16 PM   #9
71gmcC15
71gmcC15's Avatar
Re: SPID is missing
A good way to build a spid is to look at others and see what option whare available and mach what you have. For instance does your pickup have a chrome frount bumper. If yes it can be added to the spid. And so on with any other options you find your pickup has.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 08-01-2019, 08:40 PM   #10
jocko
jocko's Avatar
Re: SPID is missing
While you can determine V8 vs I6 (but not which V8), unfortunately you can't determine transmission from the VIN.
Old 08-02-2019, 11:44 AM   #11
davepl
davepl's Avatar
Re: SPID is missing
If it's a Fremont truck (Z in the VIN) we've found them stuck to the front of the bed, trapped behind the cab.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-02-2019, 08:26 PM   #12
71CHEVYSHORTBED402
Re: SPID is missing
Yep, Jeff does nice work, I can't tell the difference between his work and original, or close enough.
Both mine are Fremont. It was under the bench in the 71, and it's behind the bench in my 72. Never actually read the 72 sheet. They're real brittle at this point, it's pull the seat or shred it.
Tony
