Old 08-04-2019, 02:24 AM   #1
phraza
phraza's Avatar
Rear tire rub after lowering
Hey all,
Installed my rear drop this weekend. Loving the new height.
6" springs, trailing arms, shock relocators.
Now my rear tires rub on the inner guards (both sides). I'm still using the stock panhard bar as I haven't got an adjustable one yet, will that make a difference? See below pics.
My tires are: 255/70r15 on 15x8 rallys
Has anyone folded in the inner lip from the guard? Or cut it out? Or do I have to go thinner tire?
Any advice? Thanks in advance!
Fraser
Fraser - New Zealand
1964 Chevy C10 Stepside
350 V8
Build thread here
phraza is offline   Reply With Quote
Old 08-04-2019, 07:47 AM   #2
Katrina/10
Katrina/10's Avatar
Re: Rear tire rub after lowering
I was running the same tire size, same wheels, same problem. I decided to try 235/70 tires, and got no rubbing. Didn't really want to downsize or cut fenders, but they look ok. There's just not a lot of room in there.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 08-04-2019, 07:53 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
If you get wheels with correct back-space it wouldn't rub. Which is good news for you as you can tell the wife you need new wheels.
Stock rear end housing, 64 stepside backspace measurements I took had 6" inches on each side of the wheel mounting surface. Although I think I remember having the body shop remove a little lip from the inner fender maybe?
Old 08-04-2019, 12:25 PM   #4
MusicMan70
MusicMan70's Avatar
Back in the old days I recall guys used to take a bat and slowly roll the small end across the top of the tire, inside the fender, for that extra room.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 08-04-2019, 04:09 PM   #5
phraza
phraza's Avatar
Thanks for the advice!
It is pretty tight in there, the thinner tires sounds a good quick fix. The decrease in overall diameter of the tire didn't change the height of the drop?
Haha, might get thinner tires as a temp fix, then be on the look out for some new wheels. Dropping the front in a couple of weeks, so will see how that goes too (2" springs plus drop spindles)
Yea I've been searching fender rolling and seen people do that! Might be a last resort
350 V8
Build thread here
Old 08-05-2019, 04:24 PM   #6
forestb
forestb's Avatar
I have tried rolling my fender once and I bent the wheel well. I tried making the fenders wider by extending the fender braces and ended up cracking the paint. If you have room in between the bed side and tire I would try new wheels.
forestb is offline   Reply With Quote
Old 08-06-2019, 10:19 AM   #7
Cohi
Cohi's Avatar
Yep. Increase backspacing.
Denver/Big Island -- Instagram: Slammed66c10
'46 Fleetmaster Coupe
'64 C10 on Ridetech Air Ride
'66 C10 on GSI Bagged Chassis - in progress
'12 FLHR
'11 Custom Homebuilt Chop/Softail
Cohi is online now   Reply With Quote
Old 08-06-2019, 03:17 PM   #8
demian5
demian5's Avatar
what diff is in this truck?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 08-06-2019, 03:41 PM   #9
forestb
forestb's Avatar
The new panhard bar will not make a difference for the problem you are having if it is happening on both sides. But you will still need to get one because it will cause problems. Have you tried driving it yet? Are you bottoming out with a 6 inch drop in the rear?
Old 08-06-2019, 06:25 PM   #10
phraza
phraza's Avatar
Just got the factory diff whatever that is (12 bolt?)
Yea rolling the guards is prob a last resort. I've been looking it over and I think slightly smaller tires would make it work. Looking at the 235/70/15 size.
Bump stops have about 2-3 inches of travel before hitting the axle. I never haul anything in the rear.
Have only driven it in and out of the garage (rubbing noise is horrible haha). Installing the front drop in the next few weeks when the weather improves, so will see how that sits
350 V8
Build thread here
Old 08-07-2019, 11:22 AM   #11
scoot_mcgrute
When I lowered my truck 7", I had 235/75-15s on Rally wheels and had to roll the passenger side fender even with an adjustable panhard bar. We used a piece of scrap tube laying around and when I went to 275s on different wheels, I ended up having to roll both sides and they still rub on hard corners.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 08-07-2019, 11:58 AM   #12
vin63
It's Better With Nitro
vin63's Avatar
I wouldn't try rolling the lip of the rear fender on our trucks...the compound bends and a horizontal lip do not lend themselves well to rolling outward like the early gen. Camaros and Firebirds that have a smoother radius arch opening. Go with wheels that have more backspacing.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-07-2019, 08:27 PM   #13
luvbowties
luvbowties's Avatar
Thumbs up Re: Rear tire rub after lowering
If your 8-inchers give problems on only 1 end, it may be quicker & cheaper to find 2 newer wheels from a van--like a G-20--there are many different width wheels in that style; and the vans have identical ones except some whose width is 7". This lets you keep your fatter tires but also gives some relief between both sides of the mounted tires. I'd say those wheels come in at least 3-5 different widths. When beauty rings are on, the diff. between 7" and 8" wheels doesn't show all that much. Lastly, you could get 4 rally wheels w/all being 7 inch. **Watch this: my '66 truck would not clear using your same size tires mounted on 8-inch rally's like yours; but it got happy with the 7" X 15", circa 89-92/454 stock Chevy "SS/Dale Earnhardt" chrome wheels: the ones having 5 holes with center caps held on with inner- and outer-threaded lug nuts and black plastic center cap retainers.
Good luck,
Sam
luvbowties is offline   Reply With Quote
Old 08-12-2019, 05:50 PM   #14
demian5
demian5's Avatar
And you have no spacers bolted to the drums? This is totally odd. 8" fit, unless these were reversed or are 10"... but I put a set of 22" transports under a 60 step and had to run 1" spacers to get them to fit right and they have 1" front and 2" rear space.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 09-04-2019, 11:22 PM   #15
phraza
phraza's Avatar
Thanks for the advice guys, I managed to borrow a 8" rally with a 235-70-15 tire on it and it fits like a glove.
So will get a set of those tires and sell my 255-70-15 (near new).
Think i'll slightly bend the inner lip of my guard a couple of mm just for piece of mind. mainly to take the sharp edge away
Cheers!
350 V8
Build thread here
