Old 08-05-2019, 11:39 AM   #11
gigamanx
Re: Jesses' 48 PU
Originally Posted by Jesse49chevy View Post
Left side, spot welded in for now. Will make some square 3/16 washers for final install.
Looking real good. A thought on mounting the cab. Most of the builds, including mine, use a prothane bushing between the cab and frame. Before bolting it down for good, you may want to look into some of those. I think I just used some generic 2" discs for mine.
Plasma cutter looks like its doing real nice!
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist
Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition!
Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride
gigamanx is offline   Reply With Quote
