![]() Join Date: Jul 2016
Air cleaner and riser, 4 bbl
Clean unit, $110 shipped.
Re: Air cleaner and riser, 4 bbl
Ttt
![]() Join Date: Feb 2008
Randy,
Do you have the heat riser tube and exhaust manifold heat shields for this set up? |
![]() Join Date: Jun 2015
I was told today that a 4x4 had a 1 element then a 2 wheel drive. He said a 4x4 is 3.5 tall and a 2 wheel drive is 2.5 tall. Do you know if this is correct and if so do you know what this one came off of?
#6 | |
2wd and 4wd are the same, at least on this style which is for sure 71-72. Its probably the same for 69-70 small block too. 69 big blocks Ive had do have a shorter riser. Picture of my 72 k10 with the same air cleaner and riser. |
Shorter riser is 2 the taller one is 2 5/8
Thank you for the update there is just so much to learn about these great trucks
New price, $110 shipped
Ttt
I could do 75 shipped on just the air cleaner if interested. Don't need the riser.
I sold the sir cleaner but i have another one in similar condition so the set is still for sale.
#15 |
Active Member
![]() Join Date: Feb 2019
can you post a pic of the current setup that is for sale.
#16 |
Here you go.
#17 |
Other side
#18 |
Randy, Do you have an CARB AIR CLEANER STUD?
#19 |
#20 |
Active Member
does it come with the collar as well? with breather?
#21 |
Yes and its the taller one in the picture above, the last air cleaner was sold without that part. So this is the air cleaner lid and base with the riser, the riser has the rubber hose, clamps and valve cover fitting as pictured above.
#22 |
Active Member
Ill take it paypal coming your way
#23 |
