Old 08-07-2019, 12:05 AM   #13
hatzie
Moderator
hatzie's Avatar
Re: Gen V Swap - shop?
The Diesel models and the 1 tons got hydroboost. The boosters should still be available for a lot less than $600. Get the pedals with the booster. IIRC the brake booster pushrod pin on the pedal is in a slightly different location on the hydroboost trucks.
The power steering pump is the same.
The booster has three lines. Pressure in from the pump, pressure out to the steering box, and return.
The pressure line runs to the brake booster then continues to the power steering box.
The returns from the booster and the power steering box run through a Tee back to the power steering pump.
If you're adding a cooler it goes in the low pressure return lines between the Tee and the power steering pump reservoir. Get a used cooler off a T800 chassis in the boneyard.
The PS pump to booster will need to be a hybrid with the LS pump fitting and hardline section on one end and the squarebody brake booster hardline on the other. I'd get used hoses as donors and get a hydraulic hose outfit to crimp the proper length of high pressure power steering line between the two sections of hardline... again much less than $600.
The booster to steering box line is a squarebody part.
The return lines are SAE J189 hose with constant tension band clamps or Oetiker clamps. The only exciting piece is the Tee fitting off the steering box. Source this from your 80's squarebody donor.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
