Truck is Sluggish/Choking between 45-60mph
Today in the morning on my usual daily route to drop off my son in daycare, on straight flat road as i was getting to the 45mph mark it started to sputter, kind of holding back gasping for gas or air, so I let the gas pedal go let it slow down a bit and then again gradually speed up, it went past the 50mph mark without any sputtering or anything like that, it was normal once again. Then after slowing down and then speeding back up to the 45mph mark it began to sputter again and gasp for fuel or air, I let go off the gas let it roll for few seconds and then press the gas pedal and it goes once again past 45 without hesitation.
So on the way to and from my sons daycare it did that sluggish/choking on and off scenario. I run on ethanol free fuel only with 91 octane, there was half a tank in the truck so the low fuel is out of question, what could it be? I am thinking the carb needs a good cleaning but would like to hear y'all opinion about this issue. Any suggestions would be greatly appreciated. Its a stock 307 with three on the tree with 4 bar carb.
1969 'Matte Blackie' Oshawa Built Chevy C10 Stepside 307 three-on-the-tree |
![]() Join Date: May 2010
Re: Truck is Sluggish/Choking between 45-60mph
When did you last replace the fuel filter?
Sounds fuel supply related to me. Clogged filter or something starving the engine of fuel. At least that is where I would start.
Thanks guys, I will check the filter then and hopefully this will solve the issue.
Its a Truck Thing......
What brand of carb?
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
It came off a donor camaro from the 80's as per previous owner who did full resto,
Q-Jet, Eddy, or Holley?
Smitty
I think its a rochester stock 4 bar carb from a donor camaro, see pic
Looks like a Q-Jet. As mentioned above change the internal filter and don't over tighten it or you can crack the carb housing. Also check your throttle shaft play to see if it is time for overhaul. There is a guy in Vail AZ that rebuilds and replates them to factory standards and I have his info if you want it. If the throttle shaft is worn that will cause a vacuum leak and possibly cause your symptoms.
Smitty
![]() Join Date: Nov 2012
Sounds exactly like my 68 did when the fuel filter was clogged. It would slow down if you pressed the gas, and speed up when you let off it.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
Guest
Posts: n/a
I agree with all the fuel starvation comments above!
Thank you guys, I will be changing the filter on Monday and will let you know if that is the issue, appreciate all the input on this.
While you have the fuel line off, put the end in a litre jar and crank it over. Should fill the jar pronto if the fuel pump is good.
Disable the power to the dizzy though. You don’t want it to start when doing that. |
![]() Join Date: Apr 2016
Proceed with care. Be careful not to cross thread or strip the threads on the fuel filter inlet as it screws into the carburetor. Car parts stores carry the fuel filter, but they do not carry replacement inlet gaskets. They used to until a few years ago. There are 2 possible sizes of the fuel filter inlet gasket. That gasket is an order-online kind of part now.
There are 2 possible sizes of the fuel filter, short and long. You'll notice there is a spring behind the fuel filter. There are videos on youtube showing how to replace it, if you like. I have read it is a good idea to replace the gasket every other fuel filter change, and replace the filter yearly, so that is what I do. If you find yourself tempted to tighten the fitting more to stop a leak, stop what you're doing and get a new gasket. If you have a leak at the fuel line side of the inlet fitting, there are copper flare gaskets you can get to eliminate the need to over-tighten that. On-line order item as well. |
#15 |
![]() Join Date: Feb 2016
It is hard for me to express how right dmjlambert is without sounding like a real a22. Stripped filter treads have to be one of the top 2 or 3 reasons Q-jets get replaced. It is easy to cross thread the filter nut if you are not paying close attention to what your doing.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#16 |
Who Changed This?
![]() Join Date: Jan 2013
Indeed. I've seen dozens of these over the years. It's the same ham-handed guys who strip oil drain plugs.
#17 | |
#18 |
He means these in the link.
https://www.amazon.com/Parker-Degree.../dp/B077NHZ98C Look here for gaskets, filters etc. https://quadrajetparts.com/ |
#19 | |
#20 |
Do you have line wrenches?
Like this. https://www.amazon.com/Craftsman-Met.../dp/B007KHESG8 They come in standard sizes too. Best tool to use so you don’t round off the tubing nuts. Canuck tire should have some. |
#21 | |
#22 |
The flare gaskets I used were copper, not brass. So they are probably softer metal. I got them at Grainger. Part number 5WRW3.
I'm not clear about how to tell the difference between the 7/8 and 1 inch inlets and I have not seen a picture of them side by side to compare them. I have heard the gasket fits on each one differently. |
#23 | |
#24 |
If the carb is off an 80s Camaro it is may be a 1 inch gas inlet like my 77, it uses a nylon flat gasket. I just replaced it yesterday tried to use the old one and it was weeping a little. Got them at advanced auto pack of 10 various sizes but 4 for were correct for my rochester.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 08-12-2019 at 08:01 AM. |
