Old 08-09-2019, 11:21 AM   #1
Marty68
Extra? Shifter hole
What would have been here? Not the stomp starter hole.
Marty68 is offline   Reply With Quote
Old 08-09-2019, 11:44 AM   #2
joedoh
joedoh's Avatar
Re: Extra? Shifter hole
two speed rear shifter, or sometimes an e brake.
Old 08-09-2019, 01:01 PM   #3
mongocanfly
mongocanfly's Avatar
Russ is probably right.......but do you not have a pic of what your asking?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-09-2019, 04:59 PM   #4
mr48chev
mr48chev's Avatar
Photos help but if the trans hump is off a 4000 series the kind of slotted hole to the right of the shifter hole is for the hand brake lever. if i is not to the right of the shifter it might be for some sort of two speed.
My ongoing truck projects:
Old 08-09-2019, 08:28 PM   #5
MiraclePieCo
MiraclePieCo's Avatar
Could it be for a brownie shifter?
Back in the old days trucks often had two shifters - a main box plus an auxiliary box, or "brownie." When I learned to drive truck it was with a 5-and-4 transmission: 5-speed main box plus 4-speed brownie for a total of 20 forward gears.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 08-10-2019, 06:15 AM   #6
1project2many
If you've found the truck I had as a teenager the extra hole is for reverse. I installed a 4 speed Saginaw car transmission but I only had a three speed shifter for the top. I installed a separate rod to engage reverse by shifting into Neutral then pushing the rod down to get reverse.
1project2many is offline   Reply With Quote
Old 08-10-2019, 10:59 AM   #7
Marty68
I thought I posted a pic. It is a pop riveted patch. On s factory raised hump. I have no reason to believe trans has been changed. However a 283 has been installed. Along with the bellhousing.
Old 08-10-2019, 12:58 PM   #8
Marty68
Pic attempt #3.
Old 08-10-2019, 02:28 PM   #9
joedoh
joedoh's Avatar
handbrake, found on bigger trucks.
Old 08-10-2019, 02:33 PM   #10
1project2many
Agreed.
I'm also noticing that someone took tie to try and make a decent looking patch, especially for a riveted piece.
Old 08-10-2019, 03:14 PM   #11
Marty68
Apparently someone put hand brake on then it got removed? This fits with the theory of this truck having been a municipal or county truck. ..
Seems to have had a topper on it slot in gate for latch and pull handles welded to gate
"Posts' on bumper made from jack hammer bits. Possibly to hold road cones.
Old 08-10-2019, 11:25 PM   #12
mr48chev
mr48chev's Avatar
Those handbrakes were also on 47 3100's with 3 and 4 speeds. They didn't go to the foot brake until 48 on half and 3/4 ton.
Old 08-12-2019, 10:23 AM   #13
MJN
MJN's Avatar
The '49 3600 I used to have had a foot pedal parking brake. Both my '56 3600 and '58 36 Apache had the hand brakes.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
