![]() Join Date: Jun 2014
Lq9 - 4L80 Radiator size
Anyone try this radiator in the LS swap? I am looking for feed back on engine and trans cooling.
Thanks https://www.napaonline.com/en/p/NRS2...dInput=nr+2307 https://www.napaonline.com/en/p/NRS2...dInput=nr+2307 |
![]() ![]() Join Date: May 2015
Re: Lq9 - 4L80 Radiator size
Not sure what your putting it in...I'm running a stock replacement radiator in my LQ9 swap..its a single core aluminum...dual electric fans...will run 185deg all day long
#3 | |
I wanted a rad that fit or fit with minimal modification in the 67 but was big enough to keep everything cool. The biggest rad I could find was 28"x17" with 5 plate trans cooler. I think it will work since the 67 is half the weight as the Cadillac. I won't be running an oil cool and no a/c. Do you have a part # for the electric fan set you used? Thanks |
I dont remember the numbers..its been about 10yrs ago...it was the biggest dual fan setup I could get that would cover the radiator..got it from summit....the stock size radiator should be fine ..I pull a trailer that grosses over 9500lbs all the time ..even in 95deg weather I have no issues with it overheating....runs consistant at around 185deg...my truck came with a smallblock and I just picked up a replacement from oreillys...its the wide single core aluminum...
#5 | |
15lb
