Old 08-11-2019, 12:10 AM   #1
SierraMtns
SierraMtns's Avatar
Lq9 - 4L80 Radiator size
Anyone try this radiator in the LS swap? I am looking for feed back on engine and trans cooling.
https://www.napaonline.com/en/p/NRS2...dInput=nr+2307
SierraMtns is offline   Reply With Quote
Old 08-11-2019, 07:28 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Lq9 - 4L80 Radiator size
Not sure what your putting it in...I'm running a stock replacement radiator in my LQ9 swap..its a single core aluminum...dual electric fans...will run 185deg all day long
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-11-2019, 10:56 AM   #3
SierraMtns
SierraMtns's Avatar
It's going in my 67 c10. I wasn't sure it would be able to keep this combo cool. The stock radiator out of the Cadillac is 34"x17" with 7 plate trans cooler and oil cooler.
I wanted a rad that fit or fit with minimal modification in the 67 but was big enough to keep everything cool.
The biggest rad I could find was 28"x17" with 5 plate trans cooler. I think it will work since the 67 is half the weight as the Cadillac. I won't be running an oil cool and no a/c.
Do you have a part # for the electric fan set you used?
Old 08-11-2019, 11:15 AM   #4
mongocanfly
I dont remember the numbers..its been about 10yrs ago...it was the biggest dual fan setup I could get that would cover the radiator..got it from summit....the stock size radiator should be fine ..I pull a trailer that grosses over 9500lbs all the time ..even in 95deg weather I have no issues with it overheating....runs consistant at around 185deg...my truck came with a smallblock and I just picked up a replacement from oreillys...its the wide single core aluminum...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-11-2019, 11:31 PM   #5
SierraMtns
SierraMtns's Avatar
Do you remember what lbs radiator cap your running?
Old 08-12-2019, 12:28 PM   #6
mongocanfly
15lb
Mongo...aka Greg
RIP Dad
RIP Jesse
