You might be a hot rodder if:
You might be a hot rodder if this is how you spend your Saturday night.
![]() Join Date: Dec 2009
Re: You might be a hot rodder if:
I agree.
![]() What is this going to be install on? Great looking work. .
53 1/2 ton. 292 with 4-71 blower, billet crank and cam, 12 port cross flow aluminum head 3 Roch 2 bbl. Backed up with TKO 600 5 speed, Frankland quick change rear end with Bicknel torque arm. 12.88" Wilwood disk brakes.
Cool it was a bit hard to visualize what it was going to be at first.
I still can't recognize it; blower belt drive guard?
Edit: Okay, I found it. Respect man...
1951 Chevy Panel Truck |
Yes blower belt cover. The center section was a heavy brushed finish and the cutouts had a lot of chatter in them so I first started with 220 grit on the flats and in the cutouts. The other pieces are machined so I will start with 400 or 600 on those. The cutouts are a real PITA. I've got about 7 hours in it at this point. Sorry about the picture of my brand new Basset hounds I couldn't resist.
![]() Join Date: May 2007
gorgeous man! you dont need to worry about needing a custom milled belt cover to be thought of as a hot rodder by the way, the rest of your truck already speaks volumes.
I don't think I have many hours that my Puppy is not right there in my business .
![]() Those are some cute Puppies. ![]() Just a suggestion. If you break the corners on all those cutouts with a file set like this one in the link below it will save you a lot of time. https://www.harborfreight.com/needle...-pc-69876.html .
I'm just trying to get it flat right now. I'm working 500 miles from home right now and have limited stuff with me. Just brought a few things with me to work on. Thanks Those files are handy.
yep, been there many times.
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
