![]() Join Date: Jan 2018
GPS Speedo Option?
I am now looking for a 3 3/8" or 5" GPS speedo that is decently priced, any suggestions? I have a lot of speed traps on my daily commute and have gotten 2 tickets in the last 3 months without a functional speedo. I may go with a scangauge if these don't work but wanted something slightly more stock looking. I did the S10 speedo swap and it reads 120mpg at 40mph on my 2000 LS engine and I have been unable to get it fixed in the tune. I am afraid cable-x would do the same since it is feeding of the same VSS signal so that is why I am leaning toward GPS.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
Re: GPS Speedo Option?
I don't really have a suggestion for a GPS Speedometer that will fit in the stock dash, but what I do in my vehicles as a "temporary" solution is use a phone mount and a free GPS Speedometer app on my phone. Might save you some ticket money until you find a good permanent solution!
Not sure why your speedo would read 120 at 40? Do you have it hooked up to the correct speedometer output wire? I would think if the PCM thought your MPH was that far off it wouldn't shift right either. Does the needle go to 0 when stopped?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
This is where I have found some good alternatives for more info from your vehicle
I am sure you can find something in your price range that will work for you http://www.superdoopercheap.com/wave...3607704559&p=7
I have it hooked up to the VSS wire on my standalone harness. The needle goes to zero when stopped, it is just ~3x off...at 20 it reads 60, 30 = 90, etc. I am going to drive it with my OBD reader hooked up and see what it reads vs the speedo but I have to find a place to drive slow as over 40 mph the needle is pressing on the stop at 120 mph and I am afraid I may damage the needle or speedo having it maxed for long periods. I have a NV3500 manual trans. Perhaps my 3" more diameter tires, tall trans gears, and 3.08 rear end is throwing it off but it seems to be reading very excessive.
I do believe Auto Meter makes one and Dakota Digital, not sure on the price though. You could also just use a Garmin GPS, they show speed.
#7 | |
Did you ever get a scanner on the truck to see what MPH the PCM is seeing?
Yes, sorry I did not update the thread. I am traveling in Mexico at the moment. I did drive the truck and you are correct, the speedo reads right but my signal is 2.5x (not 3 as I thought) more than actual speed. I drove past a construction sign that provides actual speed to get this measurement. I have a new ECU coming this week where the tuner is going to input my gear/tire size/ and trans. Hopefully, this will resolve this issue, my fans not being turned on, and my motor not being able to run with the TPS hooked up (fingers crossed).
![]() Join Date: Aug 2004
I have the Autometer one, works great unless I am sitting in my carport...not sure is you can see it though
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
For the s10 mod to work your pcm is going to have to be correctly calibrated for tire size/gear ratio. The speedo output on the pcm outputs a 4000 pulse per mile signal, but it is based off of the miles per rev calibration in the tune.
If you are going to go aftermarket you dont need gps though, any of the modern aftermarket stuff can be set based on a pretty much arbitrary ppm signal. |
Old member
I have the full set of Speedhut.com gauges with GPS speedometer. Best money I spent.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I got my newly tuned ECU back and the speedo is calibrated fairly correctly now. Glad to get this resolved although I have new issues/resolutions with each boxed tune I get.
