Old 08-17-2019, 06:47 PM   #1
tdangle
tdangle's Avatar
Brake Booster
Does it look I have the correct booster? C20 7500 GVW Drum all 4 corners. The reason I ask is the brakes work fine except I feel it takes too much pedal pressure. This is a factory power brake truck
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 08-17-2019, 07:05 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Brake Booster
That's what mine looked like before I upgraded to front disc brakes. Probably correct, then. Plug the vacuum line and see how much difference it makes. It might be going bad, that might help you tell.
~Steven
Simi Valley, CA
Old 08-18-2019, 12:00 AM   #3
jkeady
jkeady's Avatar
Re: Brake Booster
That’s correct (looking.) I noticed my brakes were taking quite a bit of effort to stop effectively a while back. Kind of snuck up on me. Anyway, my front brake shoes were just very old and getting badly glazed. New shoes (and brake hardware) has it stopping really nicely. Not saying that’s your problem but definitely investigate.
Josh
'70 Custom Camper / 20
jkeady is offline   Reply With Quote
Old 08-18-2019, 11:09 AM   #4
tdangle
tdangle's Avatar
Re: Brake Booster
That is actually a good possibility. Linings are most likely about 15 years old. Not many miles, but still wondering if linings actually get old. I think I'll pick up a set of shoes and see what difference it makes. At the same time clean and refresh the bearings.
Terry
Old 08-18-2019, 12:33 PM   #5
jkeady
jkeady's Avatar
Re: Brake Booster
Shoes are so cheap, makes sense to replace a 15 year old set if they’re suspect.
Josh
