Old 08-23-2019, 06:12 PM   #776
dflarsen77
Active Member
Re: What did you do to your truck today.The 3rd chapter
How much is R12 going for. The shop I talked to madd it sound like a hundred bucks a pound if you can find it.
David Larsen
1970 Chevrolet C-10
dflarsen77 is offline   Reply With Quote
Old 08-23-2019, 06:20 PM   #777
Ken O.
Just spent a crapload of $$ to get the tranny fixed in the 96 Silverado (along with a transfer case seal, rear main seal and new U-joints) so I can drive it instead of using my 67 GMC as a daily driver.
Ken O. is offline   Reply With Quote
Old 08-23-2019, 07:09 PM   #778
Astro-Balls
Astro-Balls's Avatar
Removed front and back glass for Upper cab paint this weekend, new glass to install and new door weatherstrips.
Minimal rust found which is always a plus.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 08-24-2019, 08:07 AM   #779
72c20customcamper
72c20customcamper's Avatar
When they instituted the ban on r12 we bought a 4 or 5 30lbs cylinders for real cheap just before the cut off date. The distributor wanted to get rid off it before he had to eat them. Still have 2 left and the open one. . I do have my uncles recovery system . So I reuse the old and just top off with new.
Vendor at the truck nationals was selling one pound disposable cans for 40$
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-24-2019, 08:43 AM   #780
CG
BlahBlahBlah
Nothing ... again
Old 08-24-2019, 03:02 PM   #781
67C10Step
67C10Step's Avatar
In the process of disassembling the step side bed. Got all the old wood out and the fenders and steps off.
Bed sides probably usable as well as the sills. Bed front and rear cross sill will have to be replaced. Few more bolts and I’ll have it all apart. Will probably jump to cleaning up rear frame and do rear brake and suspension work before tackling stripping the bed for primer.
67C10Step is offline   Reply With Quote
Old 08-24-2019, 03:42 PM   #782
Boog
laying low
Boog's Avatar
turn
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-24-2019, 03:56 PM   #783
Boog
laying low
Boog's Avatar
I have my step bed nearly as disassembled as yours. I bought a new headboard, cross sills, corner angle strips and floor strips for mine along with all new hardware. My bed sides are in pretty good shape. I hope to blow mine apart before long and get all that done.
Boog
primer is finer
Old 08-24-2019, 05:47 PM   #784
67C10Step
67C10Step's Avatar
Boog,
Where did you order your bed parts? I’ll need angle strips as well. And all the bed wood and hardware as well but I’d like to get all the metal parts first.
Getting this apart for easy access to the rear frame to do brakes, springs, and all the usual stuff.
Old 08-24-2019, 06:02 PM   #785
CamTra
CamTra's Avatar
Got her off the trailer and started my plans for a build. Made a deal to have a 454 built for her. Started planning my drum to disc swap and in my mind decided to paint her bright red instead of the dark maroon color. Will build her with my 21 year old son, so I'm excited to get started.
CamTra is offline   Reply With Quote
Old 08-24-2019, 08:12 PM   #786
BigBird05
I started drilling out about a 1,000 spot welds on the donor lower cowl vent. Then I can drill out the one on my truck. Going to replace the rusted cowl.
BigBird05 is offline   Reply With Quote
Old 08-24-2019, 09:20 PM   #787
Boog
laying low
Boog's Avatar
Originally Posted by 67C10Step View Post
Boog,
I bought my metal from LMC. I haven't bought the wood yet. I'll probably cut my own again.
Boog
primer is finer
Old 08-25-2019, 02:46 PM   #788
72c20customcamper
Finished up the air box .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-25-2019, 10:54 PM   #789
Thrill4130
Active Member
Thrill4130's Avatar
Fixing some wing windows for my shortbed. Replaced the locking part that wraps around the glass on 67’s. Waiting on rubber and more rivets.
Thrill4130 is offline   Reply With Quote
Old 08-25-2019, 10:55 PM   #790
Thrill4130
Active Member
Thrill4130's Avatar
Old 08-26-2019, 09:37 AM   #791
66clow
66clow's Avatar
Made a apron bracket, finished making my filler panels(still need to paint them) and cleaned her up.
66clow is offline   Reply With Quote
Old 08-26-2019, 10:21 AM   #792
70-Chevy
-Chris
70-Chevy's Avatar
Started putting on the Wilwood disc brake kit on the rear end until I realized I had the wrong Moser axles.....so, I went ahead and put the front bumper on and got a brake pedal assembly coming from SpecialyRetail this week. Going back at it next weekend....
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt.
BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481
2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's
2017 Chevy Suburban (Wifes Car)
- Fully Loaded & Stock
"Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem."
Ronald Reagan, President of the United States; 1985
70-Chevy is offline   Reply With Quote
Old 08-26-2019, 07:04 PM   #793
72c20customcamper
Finished up the passenger door piller
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-26-2019, 07:50 PM   #794
66clow
66clow's Avatar
Removed the snorkel
Old 08-26-2019, 08:36 PM   #795
c10 71
Cool Re: What did you do to your truck today.The 3rd chapter
So I carefully cut the frame
c10 71 is offline   Reply With Quote
Old 08-26-2019, 11:31 PM   #796
lintcollector
Talking Re: What did you do to your truck today.The 3rd chapter
Took it around the block for the first time ever. Felt GREAT!
Thx, Lintcollector
'72 C10 Fleetside Big Block
See my build thread here:
http://67-72chevytrucks.com/vboard/s...d.php?t=771552
lintcollector is offline   Reply With Quote
Old 08-27-2019, 10:37 AM   #797
lintcollector
Love that idea to get it up higher off the ground, might have to make my own!
Do they just stack up, or do you have them anchored together somehow?
Thx, Lintcollector
Old 08-27-2019, 04:36 PM   #798
72c20customcamper
Hung the radiator support and bolted on the door and fender . Both OEM pieces everything lined up pretty well even the rocker with a few 5 pound sledgehammer plows on a 2x4 . Came to the cab corner . It was a cluster ###! . It was almost like it was for an extended cab . Had to cut it into 3 pizza slices just to get it to line up. 5 hours I would rather not repeat. Other side is getting a few small pieces.
If anyone is doing cab corners stay away from the CHL brand
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-27-2019, 04:58 PM   #799
Barnfind46
Barnfind46's Avatar
The Chevy trucks in Taiwan are different than ours. He He!
68' with no bells or whistles unless I add'em.
Barnfind46 is offline   Reply With Quote
Old 08-30-2019, 08:47 AM   #800
OregonNed
OregonNed's Avatar
A friend helped me along in my interior project by painting these interior parts for me
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
