![]() Join Date: Jul 2016
Tilt Column, column shift auto, motorhome conversion
These motorhome columns have the short inner shaft stick out that is the same as a truck so no modifications are needed to the intermediate shaft and they are a true bolt in.
The motorhome shift arm has a dogleg in it which doesn't affect how it shifts, its just different looking. I completely disassembled this and moved the neutral safety switch to the truck location. It was bead blasted primed and painted gloss black. It has a new lower grommet and retainer, the upper grommet is nice used. The turn signal lever and tilt lever are new. Shifter pin hole is nice and tight. Turn signal switch was disassembled, cleaned and lubed. All parts were inspected lubed and set to factory specs $429 shipped. . Last edited by randy500; 08-02-2019 at 02:54 PM. |
Re: Tilt Column, column shift auto, motorhome conversion
Couple more photos
Beautiful column.
Ttt
Ttt
laying low
![]() Join Date: Mar 2001
Randy is the metal wiring cover from a non tilt column the same as one for a tilt column? I see there is no cover on that column.
laying low
Ok. Will you accept a postal money order?
laying low
Bump
The package arrived today.
Great, Good to hear that.
laying low
Randy were the levers not included ? I didn’t see them in the box.
