Truck addict
how to check a fuel pump?
What is the best way to see if my fuel pump is still working properly?
1956 Chevy Napco 1972 Cheyenne Super 1970 K20 |
unsrew the inlet to the carb put a hose on it into a jar turn the motor over for 5seconds and see if you've got gas in the jar
#3 | |
Buy a clear inline filter with replaceable inserts and see the fuel pumping.
#5 | |
![]() Quote:
Probably the best way is to use a line pressure gauge on the discharge side of the pump while the engine is running. NAPA sells a decent gauge that is a pressure/Vacuum gauge that works well.
Larry 72 Chevy SWB 4x4 71 Chevy SWB 4x4 My Work Truck "Don't confuse enthusiasm with capability" |
Watch out for your cornhole !
![]() Join Date: Jun 2003
A new fuel pump is about 15 bucks. How much trouble is it worth to you to just put a new one on?
Truck addict
Tx Firefighter, thats a good point, but I would rather check it so if it is ok I can spend the $15 else where as the truck does need alot.
How much pressure is the fuel pump is suppose to put out?
stock pump not much maybe 4 5 psi max?
