Old member
I bought this LED bar to go on my 71 but ended up buying new tail lights and cargo 3rd brake light in stead.
So I decided I would use it on the ramp truck. I had the flat 4 pin connector so why not. Man that was a job. The truck wiring was a mess under the truck. PO had cut and taped up all kinds of splices with no connectors just tape. I cut 8' of wire out of the harness and redid it all. The lights work well now. I even went and bought new flasher and LED tail lights to go in it also. Made a world of difference. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Ramp truck LED
Are those the ones that push into the rubber ring?
If so,that's what I have on my 82 hauler.I have the rectangular ones up on the rack too. Also,led side markers. Sure is bright at night! Look good too! Mike. ![]() |
#3 | |
Old member
Re: Ramp truck LED
I have LED driving lights up front. Here is the front. ![]()
Re: Ramp truck LED
Looks good. I can see you! I have four of those round tail lights laying around, and crossover harness from the '95 I totalled that had a utility bed. I just need a truck for them
#5 | |
Old member
![]() Quote:
It's all better now though. I may start adding the LED side marker's soon. I added the relays up front for the head lights and I may get a set of new head lights for it. ![]()
