Old 06-07-2004, 03:35 PM   #1
Tuttles
Looking for lift kit for a 2wd 88-90 burban
Just wondering if anyone could help me out. What is the best lift kit for a 2wd 88-90 suburban. I've been wanting to lift it yet have not been able to find many available. Thanks for any help
Tuttles is offline   Reply With Quote
Old 06-08-2004, 12:13 AM   #2
Dropped90Burb
Dropped90Burb's Avatar
Our suburbans(73-91) have the same suspension as the 73-87 pickups. Get ahold of Fabtech Suspensions and look for a lift kit for the 73-87 C-10. They wont have a listing for the suburbans. They have the best lift kits for the 2wd. Hope this helps.
1990 Chevy Suburban 1/2 ton 2wd
1988 GMC Suburban 1/2 ton 2wd
Dropped90Burb is offline   Reply With Quote
Old 06-08-2004, 01:46 PM   #3
Tuttles
Thanks for the help much appreciated
Old 06-09-2004, 12:15 PM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
How much lift do you want?
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 06-09-2004, 04:53 PM   #5
Tuttles
I was think round 3-4 possibly six depending on how much it will cost me for a quality kit
Old 06-10-2004, 02:49 AM   #6
aggiedave98
I just went through this. Fabtech is the ONLY option available for 2wd...
http://67-72chevytrucks.com/vboard/s....php3?t=106508
Let me know if you want more info.,
aggiedave98 is offline   Reply With Quote
Old 06-10-2004, 01:03 PM   #7
Tuttles
do you like the fabtech basic kit. I was wondering if the long travel was really worth it just for basic driving and hopefully some fun stuff later. It definetly improves the look i like it on yours aggiedave
Old 06-10-2004, 03:53 PM   #8
aggiedave98
well, it really depends on $$. The 3" basic is just a stronger spring (compresses less, but it's the same height as the original one) and a ball joint spacer.
It was hard for the guy to get the alignment done b/c the geometry is changed. It drives pretty well. If it's just for the street, I think it's a good choice. Not sure if offroading would really make the long travel a better choice.
glad you like the burb... I do.
Old 06-15-2004, 05:06 PM   #9
Prerunner1982
Prerunner1982's Avatar
there are a number of ways to do this. you could go with a 3" lift spring or coil spring spacer. the addition of the ball joint spacers helps the alignment problem a bit. you can also go with tubular control arms, though i am not sure how much this helps anything except looks. the rear is easy, you could go cheap and go with blocks, new lift springs, or a shackle flip. you could also just do a body lift.
Prerunner1982 is offline   Reply With Quote
Old 06-15-2004, 11:00 PM   #10
aggiedave98
what exactly do you do for a shackle flip?? and don't tell me flip it...
Old 06-17-2004, 11:20 AM   #11
Prerunner1982
well flip it... aggie this wont fix your problem....
you can either cut a slot in the original bracket and put the shackle down, instead of up, you can use a spring mount from the front of the rear springs as a rear shackle hanger, or you can buy a kit that already has the hanger made...
do a search in the 4x4 forum here, or go to coloradok5.com and do a search there you will find a load of things.
