Old 08-30-2019, 05:31 PM   #18
SilveradoDude
Question Re: Truck turns over but won't start
Originally Posted by kipps View Post
Disconnect the fuel line as it enters the fuel pump. Push a foot or two of hose onto the pump, and drop it into the open neck of a fuel can. The fuel canister can be sitting on the ground, and it should pull from it fine.
I started a c60 dump truck this method. Started and ran perfectly. Once I had it running, I replaced the fuel line back to the tank, and was able to drive it.
Thanks, and the inlet line is the larger of the two hoses correct?
SilveradoDude is offline   Reply With Quote
