Old 08-31-2019, 01:42 PM   #1
SierraMtns
SierraMtns's Avatar
LS Power steering pump, Hydroboost vs non-hydroboost
Does anyone know if the power steering pumps with Hydro boost have higher pressure then the non-hydro boost pumps? The only difference I can find so far is they have an extra re-turn line.
I am working on power steering lines this weekend on the 67.
SierraMtns is offline   Reply With Quote
Old 08-31-2019, 02:44 PM   #2
mongocanfly
mongocanfly's Avatar
Re: LS Power steering pump, Hydroboost vs non-hydroboost
I read all I could find on the 2 pumps and never got a clear answer....so I added a extra return fitting to my stock non-hydroboost pump....I also have a hydroboost pump on my C30 and see no difference between the 2 other than the extra hose barb
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 08-31-2019, 08:44 PM   #3
clay68c10
clay68c10's Avatar
I’ve heard if the donor vehicle had a steering box you are ok, and if it had a rack and pinion you will have low pressure. I don’t know if this is legit or here-say.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-31-2019, 11:25 PM   #4
Captainfab
60-66 Nut
I hadn't thought about it but that makes sense since a R&P operates at a lower pressure than a steering box.
Old 09-02-2019, 10:39 PM   #5
solidaxel
solidaxel's Avatar
Waiting for some good numbers, on either one!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-04-2019, 11:41 AM   #6
SierraMtns
SierraMtns's Avatar
Yeah finding a pump that came out of R&P car is a good idea. I never like having a over powered steering system.
Old 09-04-2019, 12:38 PM   #7
e015475
e015475's Avatar
Pressure you can adjust with a spring on the discharge port of the pump. Flow is a function of displacement of the pump. A hydroboost and a rack will take more flow than just the rack.
I'd run the type 2 Saginaw pump that came on your LS motor first to see how it works. Is there any LS motor that came in a truck or car that didn't have a rack and pinion?
Off road cars running the LS Saginaw pump often use a ram steering setup and there's higher flow Saginaw pumps to meet the higher demand of the ram steering.
If you need more flow, you can buy a bigger pump from Howe Steering and several others. LS trucks have a different steering pump shaft size than cars do, so be careful.
They also sell different pullies for the Saginaw TC pump that will change the flow rate.
e015475 is offline   Reply With Quote
Old 09-04-2019, 06:59 PM   #8
Pontitruck
Pontitruck's Avatar
Chiming in here to learn as my swap 5.3 has 3 fittings and I was trying to determine if I could just cap one off and use it or needed to get a 2 port pump. I’m assuming my donor had hydroboost.
Pontitruck is offline   Reply With Quote
Old 09-04-2019, 08:07 PM   #9
mongocanfly
yes. you can just cap off one of the return line ports on the tank..no problem..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 09-04-2019, 10:54 PM   #10
SierraMtns
SierraMtns's Avatar
Yes I am clamping off the upper of the 2 return lines.
