09-02-2019, 10:43 AM | #326 | |
Re: Frankentruck
On this new speedo, when I got it, I noticed that the end of the old speedo had broken off inside where the cable goes in. I though I got all the broken stuff out, but I'm not certain. I think what I'm going to try is to put the odometer roll from the new speedo into the old speedo and see if that works
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
09-08-2019, 12:54 AM | #327 |
Re: Frankentruck
Saturday morning, I jumped in the rust bucket and drove up to the Chattahoochee National Forest to see my buddy get married. On the way up, the broken speedo bothered me so much that I just unplugged the speedo cable at the cluster. Once I got back home, I swapped back to the original speedo and put the odometer roll from the new cluster in it. Drove it about 2 miles just to have the odometer roll stop spinning again. That's twice now, and unfortunately, the 64-66 odometer rolls are larger than the 60-63s. I really want a working odometer, but I don't want to spend over 100 bucks for a new speedometer when my speedo works just fine without a stuck odometer roll.
It was pretty fun givin' her the beans on some dirt roads
09-08-2019, 10:34 AM | #328 |
Re: Frankentruck
Beans, Beans, good for your truck...
09-08-2019, 05:40 PM | #329 |
Re: Frankentruck
09-15-2019, 11:10 PM | #330 |
Re: Frankentruck
Drive it like ya stole it...LOL
Former Decorated Combat Marine...Semper Fi!! Instagram jorourke322 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=734699 2019 GMC AT4 |
09-16-2019, 10:07 AM | #331 |
Re: Frankentruck
I have been whenever I've been home, but I won't be able to drive her again until October 11th. That will be the next time I go back home, and that weekend I'll bring her back to Milledgeville as my daily driver for a little bit. The Deep Roots Festival is October 26th, and part of the festival is a car show, so I'll have the truck in the show just to crust up the joint
09-16-2019, 03:30 PM | #332 |
Re: Frankentruck
I messed around with the original speedo, but found out I had some plastic gears that were worn out. I just bought a new one and now my '61 speedo works good.
09-16-2019, 04:16 PM | #333 |
Re: Frankentruck
Drive her.... and enjoy to the fullest
Check out my build here http://67-72chevytrucks.com/vboard/s...d.php?t=768039 She may not be the prom queen but at least she puts out.. |
09-16-2019, 04:38 PM | #334 | |
Re: Frankentruck
That's the current plan! Continue to drive her until parts start falling off, then I'll start the rust repair
09-17-2019, 01:28 PM | #335 |
Re: Frankentruck
If you look back in the thread, I had picked up an Igloo Little Kool Rest to add some cup holders and the ability to keep mom's cooking cold on my trips back to college. Last week, I found the big brother. I got an Igloo Kool Rest off of Facebook Marketplace for a great deal. I would prefer a tan one, but I just couldn't pass this one up when I found it
09-18-2019, 10:48 AM | #336 |
Re: Frankentruck
that's awesome
09-18-2019, 02:16 PM | #337 |
Re: Frankentruck
Love it!!!
09-18-2019, 08:20 PM | #338 |
Re: Frankentruck
Thanks guys, I can't wait until I get it home and in the truck!
09-19-2019, 03:04 PM | #339 |
Re: Frankentruck
That thing is really "kool"
1965 chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601 1976 chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037 1978 chevy c20 350 4speed 1998 chevy c1500 4.3L 5speed 2002 Chevy s10 4.3L auto 4x4 Plus a Mercury & some Fords... To many projects! |
09-20-2019, 10:27 AM | #340 |
Re: Frankentruck
Christian,
I just went through your entire post here and i just want to say "Thank you!" Thank you for striving to help others, thank you for your dedication to Christ. It was just awesome to read about all the other fellow Christians on here. May God use you to the most in your daily walk with him, God Bless my Friend. Ok, to the truck. Nice ride there sir. It is coming along and it has been great reading on your process and how you got to where you are. I cannot wait to read updates. |
09-20-2019, 01:59 PM | #341 | |
Re: Frankentruck
extremely kool
10-07-2019, 11:26 PM | #342 |
Re: Frankentruck
Frankentruck has just been sitting back at home. This weekend is our fall break, so I'll be going back home and bringing her back to Milly with me.
The Deep Roots Festival is on the 26th of October this year, so of course I'll be hanging out downtown all day with Frankentruck and all the other cars. Can't wait to be driving her again
10-11-2019, 11:41 PM | #343 |
Re: Frankentruck
Got home today for fall break, and before I walked into the house, I jumped in the truck to see if she would awaken from her month long slumber. Happy to report that after turning over enough to build oil pressure and turn the dummy light off, gas finally got back to the carb and she fired right up. I wiped the cobwebs off and got started on the tasks I needed to get done.
First up was to pull the cluster and swap speedos again so that I can send off my best one to Tom and have it rebuilt. I'll send that out on Monday once I get back to Milledgeville. I put the junky one back in so that I can at least have the cluster look complete even though it doesn't work After that, I turned my attention to fixing the lights on my tach. The lights went out over a year ago, but I finally took it apart to see if I could make it work again. The right LED would only work if it was pressed on, so I think something broke inside the little LED. I ended up trying to solder the attachment joints and that didn't make it work. What's the next best thing? Run some solder to jump the busted LED and boom, one side works again. I only need it to light up to 5k anyways because once I'm past that, I'll start floating valves. When I put the new under dash wiring harness in a few years ago, I never hooked the trailer brake controller back up. Turns out it was real simple to do, so I hooked it back up and I think it still works. I don't have a trailer with brakes to test it out on though. Once I get back to Milledgeville, I'll give her a much needed bath
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson Last edited by cwcarpenter98; 10-11-2019 at 11:56 PM. |
10-28-2019, 10:13 AM | #344 |
Re: Frankentruck
Saturday was the Deep Roots car show in downtown Milledgeville, so of course Frankentruck had to show out
The 71 Ford next to me has the Ford version of the 3 speed overdrive trans. Pretty neat to see some other trucks with that transmission in it. It was a great time being able to hang out with Jhrusk and get some inspiration from his new build for mine. Frankentruck might get a couple inches chopped out by next summer
10-28-2019, 10:16 AM | #345 |
Re: Frankentruck
Some sunset pics for your viewing pleasure
10-28-2019, 10:22 AM | #346 |
Re: Frankentruck
Nice pictures as usual Christian. I went to that car show about 4-5 years ago. It is always good. I will have to make it back one of these years with my truck.
10-28-2019, 10:26 AM | #347 | |
Re: Frankentruck
If your truck is back on the road by next year, bring it on up!
11-04-2019, 11:51 PM | #348 |
Re: Frankentruck
Got my speedo back from Classic Gauge and Cluster today! Tom went above and beyond to restore my speedo and odometer to working condition at a great price that any college student can afford.
Tom replaced the old odometer roll that had stuck with a good, working one, replaced the gears inside the odometer that were chewed up, repainted the speedo needle, and checked to ensure the speedo was calibrated correctly. He also repainted the back of it to make it all look nice. Check out Classic Gauge and Cluster on Facebook or TBONE1964 on here for all your cluster repair and restoration needs. Tom does great work, and I'm stoked with how it turned out. I haven't had a working odometer in Frankentruck for years It's so nice to have the entire cluster back to working condition.
11-05-2019, 03:53 PM | #349 |
Re: Frankentruck
Glad you got it working Christian!
The speedo in my 65 has been acting up sometimes so it looks like I'm going to be having my own fun with speedometers sometime soon lol.
11-06-2019, 01:32 AM | #350 |
Re: Frankentruck
Honestly, I would just send it to Tom if I were you. He can make sure that it will work for you and can clean it up real nice if you want him to. Once I get to the point of buying another truck (after college ), first thing I'll do if I need any speedo work will be to send it to Tom
