Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WTB Parts
Old 06-28-2019, 10:04 PM   #1
oldwagon
oldwagon's Avatar
Quadrajet carb
I need a quadrajet carb, either in rebuildable condition or ready to mount and run, with the 12v choke setup in a real bad way. I know they are getting real hard to find but if anybody has a spare they would be willing to part with let me know. If not, hopefully, someone can put me on the tail of one. Thanks for any help. 650cfm would be great.
oldwagon is offline   Reply With Quote
Old 06-30-2019, 10:47 AM   #2
SmirchIs#1
Active Member
Re: Quadrajet carb
I have several.I will need to know more about your application to see that you get the appropriate carb.Dennis
SmirchIs#1 is offline   Reply With Quote
Old 06-30-2019, 04:40 PM   #3
oldwagon
oldwagon's Avatar
Re: Quadrajet carb
Dennis, I need it for a GM 305 motor. Do not want the computer control version as I have removed most of that. Need the older style if possible. Yes, let me know if you have something. Thanks. Veryl
Old 06-30-2019, 08:47 PM   #4
SmirchIs#1
Active Member
Re: Quadrajet carb
I have 40-50 Q-jets because I build them and other carbs as well.I'm sure I have something now that I know what you have.I'll check tomorrow.I have old parts listings,so I can pick a correct carb for you.Dennis
Old 07-01-2019, 09:36 PM   #5
oldwagon
oldwagon's Avatar
Re: Quadrajet carb
That's great Dennis.
Old 07-06-2019, 05:15 PM   #6
SmirchIs#1
Active Member
Re: Quadrajet carb
I found a carb that will work for you.I took it apart to make sure it is buildable.Took pics so you can see the inside of carb for yourself.I can't seem to be successful getting pics out here.I will try though
Old 07-07-2019, 09:48 PM   #7
oldwagon
oldwagon's Avatar
Re: Quadrajet carb
Dennis, I'll keep an eye out for the pics.
Old 07-08-2019, 07:38 AM   #8
Getter-Done
Getter-Done's Avatar
Re: Quadrajet carb
Here one of the post of how to post pictures.
Link:
http://67-72chevytrucks.com/vboard/s...d.php?t=627506
In the future I would have an interest in a Quad.
Hope this helps my friend Oldwagon get a carb.
The early bird gets the worm,
85 Chevy K-20
Old 07-08-2019, 09:36 AM   #9
SmirchIs#1
Active Member
Re: Quadrajet carb
Just wasted half hour trying.Here we go agin.Thanks for your help though. Just so you know,this disassembly was done in a dirty environment,as it has to come apart again.Don't want you to think that I would build a carb around those conditions
Old 07-08-2019, 10:53 AM   #10
oldwagon
oldwagon's Avatar
Re: Quadrajet carb
I understand the condition(s). What might you be asking for it as is or after a rebuild?
Old 07-09-2019, 09:49 AM   #11
SmirchIs#1
Active Member
Re: Quadrajet carb
$125.00 plus ship as is.I am running up to 3 weeks behind right now,so don't want to take on more work.If I did build it would be $350.00-$400.00 plus ship.I check the carb top for warp & usually need to file it flat.The welch plugs in the bottom of the carb body,always need to be epoxied,then filed to fit back in the recess of the carb base plate and besides a new kit I install brass floats.
Old 07-09-2019, 04:20 PM   #12
oldwagon
oldwagon's Avatar
Re: Quadrajet carb
Smirch, I think I'll pass. Thanks for letting me know what you have.
Old 07-23-2019, 10:01 AM   #13
Wrenchbender Ret
Re: Quadrajet carb
I just saw this ad. Do you still need this Q-jet. I have one. I will get to the shop tomorrow & can get photos of it.
George
Wrenchbender Ret is offline   Reply With Quote
Old 07-23-2019, 08:38 PM   #14
oldwagon
oldwagon's Avatar
Re: Quadrajet carb
George
Yes, George, would like to see some photos. Thanks.
Old 07-24-2019, 10:11 PM   #15
Wrenchbender Ret
Re: Quadrajet carb
Here are photos of the Q-jet carb. the number is 17059222.
There is negligible wear on the throttle shaft. The metering rods go down & spring back. It has the heated type choke coil but an electric coil fits in it.
$50 shipped.
George
Old 08-19-2019, 10:00 PM   #16
oldwagon
oldwagon's Avatar
Re: Quadrajet carb
George, still not sure that it's a carb problem. Kind of in a dilemma right now. Appreciate you putting up the pics. Sorry it has taken so long to get back to you.
Old 09-02-2019, 08:20 PM   #17
oldwagon
oldwagon's Avatar
Re: Quadrajet carb
George, I will take this off your hands if it is still available. Sorry it took so long to get back to you. Pm me with payment info. Thanks.
