Old 09-04-2019, 06:43 PM   #1
LuckyDSquared
Headers too close for comfort...
Hey all. I’m swapping a 350/350 into my ‘62. I went with Sanderson Patriot headers because that’s what my buddy has in his ‘60 with a 327/350 combo. Anyways, the passenger side is awfully close to frame rail and drivers side is awfully close to motor mount perch.
Do you all think they are too close for comfort? Should I apply some heat to the bends and “persuade” them to fit better? What are y’all ideas?
LuckyDSquared is offline   Reply With Quote
Old 09-04-2019, 09:02 PM   #2
pholmes350
Re: Headers too close for comfort...
Nah, my passenger side is touching the frame. I gotta fix that.
pholmes350 is offline   Reply With Quote
Old 09-04-2019, 09:21 PM   #3
SkinnyG
SkinnyG's Avatar
I like to shoot for a finger-width of clearance, you could get away with half a finger-width. Probably depends on how much the engine moves. I have polyurethane mounts in the stock clamshells on my '77 daily, and the motor hardly moves at all, so I can be a lot closer with the exhaust. I will likely do the same on my '61.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 09-05-2019, 11:42 AM   #4
MikeN
MikeN's Avatar
I don't think you'll have any trouble with that. Worst it can do is give you a little vibration inside the cab if it were to settle to the point where one side or the other were actually touching. If that happened, I'd grind a little bit on the frame for clearance. On the other side, I'd gently ding the header tube.
MikeN is offline   Reply With Quote
Old 09-05-2019, 03:23 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
I call that clearance.
Old 09-09-2019, 01:47 PM   #6
cj847
cj847's Avatar
Any further from the frame rail, puts it closer to the starter.....so I think it's plenty of clearance.
cj847 is offline   Reply With Quote
Old 09-09-2019, 01:49 PM   #7
demian5
demian5's Avatar
That is plenty of room.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 09-09-2019, 05:09 PM   #8
MikeB
MikeB's Avatar
I'd say you want a 1/2" minimum, depending on how much engine rock you have when you blip the throttle. Or install some polyurethane mounts and the engine will rock MUCH less.
Also, make sure the header tubes have a few inches clearance to brake and fuel hard lines. if not you can wrap the lines with a heat reflective material.
Here are some that use velcro, so you don't have to disconnect
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is online now   Reply With Quote
