BlahBlahBlah
How did you get cab, box, burb, panel, blazer off the frame?
I would like to see how you got your truck cab and box, or your burb/panel body, or your blazer/jimmy off of your chassis.
But I only want to see how you did it without using a lift or tractor or anything that made it pretty easy. I know people have used engine hoists for cabs and boxes. That seems relatively easy solution when you have only one or two sets of hands. Probably figure out a way to use it when lifting one of the bigger bodies? How bout those big bodies like burbs and blazers? I know some of you figured out ways to get those bodies up in the air so you could roll the chassis out. How did you do it without getting all your friends and promises of beer and pizza? Its a serious question. I know a lot of you are great about thinking outside the box. Lets see or hear about your lifting powers. And once you got your chassis rolled out what did you do with the body? |
![]() Join Date: Dec 2009
Re: How did you get cab, box, burb, panel, blazer off the frame?
CG
Here's a couple of pictures of my cab being removed. I do have an A-frame but I chose to remove everything from the cab and flip it on it back on a piece of plywood. Then roll it down some 2x8's off the frame onto a trailer. Doing it this way left my engine, trans and driveline all intact. I then took it to a (Blast from the Past) sandblasting place. I think having the floor-pan blasted a little helped me to see better how to remove the floor-pan for replacement. .
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
BlahBlahBlah
Nice job! Very outside the box, I never would have come up with that.
I did simular to Getter Done, removed bed with engine hoist... lift cab with jack about 4" roll on to its back. Onto a sheet of plywood with padding. No glass...Removed engine and trans did all work on cab with it on the frame. Painting roof, floor cowl, dash all strait on, much easier.
I went kind of old school. Pics may be in my thread below.(72 Blazer) I used 4x6 pressure treated timbers and blocks. I lifted each corner a little at a time and just added a block or two. Eventually I could roll the frame out from under it. Cheap cuz I just bought bent up lumber from Lowe's at a real discount and used blocks I already had but blocks are like a dollar. It was on these blocks through a hurricane (not a direct hit) but it was damn solid.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; 09-07-2019 at 08:27 PM. |
I just bought and assembled a commercial Gantry Crane used that is 14 ft tall and 14 ft wide to do my heavy lifting . Have not yet used it but will soon .
#7 | |
BlahBlahBlah
I'm pretty sure Ive read some burb fellas actually did it themselves (somehow). I think the only thing Ive muscled off myself is a bed. For awhile I was lucky enough to have a loader tractor I could use. When I took my panel body off the frame it took a pretty good handful of guys helping out. There just has to be better safe ways for people that love the hobby but don't have the resources others have. Couple of good ideas so far. I'm going to try to figure out a way to get my panel back on its chassis just to see if I can. If I disappear from the board you'll know it was a miss =) |
#8 | |
I’m a cheater then...also have an electric chain hoist for it!
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
Where's my beer?
4 guys and beers afterwards got a parts cab removed from a frame for me. The cab was stripped of everything except the windshield. No doors either. I put it on a pallet in my garage to which I had attached heavy duty casters so I could roll it around.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
I have roughly $700 in my Gantry Crane , my chain hoist is manual for now but that could change .
![]() Join Date: Apr 2008
I used cribbing and rolled the chassis on a floor jack on my extended cab
$800 in mine including the 2T Dayton chain hoist.
I went to the lumber yard, bought enough 2x10’s to span my 2 car garage and be tripled up. I think they’re 16’ long, not long enough but I staggered the joints and added a 4th piece so every joint is covered on both sides. Bolted it all up with big hardware, added some wall reinforcement and it pulled an engine no problem. This beam is at the back 1/3 of the garage, I plan to add another towards the front when I pull the cab.
I’m thinking of borrowing some heavy duty ratchet straps from work. Jack the truck up, run the straps under the cab (front to back) to the beams, tighten, lower the chassis and roll it out. Then I can play with jacks and the straps to lower it onto a dolly or something. I can do something similar with the bed grabbing it from each corner. In my head it sounds better than the cab sliding off cribbing or a jack stand, I can do it single handed, plus I’ll have another heavy beam in my garage to do stuff with. I don’t see why a similar setup wouldn’t work for a burb or panel body. The straps would have to run left to right and downside it might be harder to balance. Plus I don’t know if you have a garage, it’s construction, where your body is, what it’s on, so there’s those logistics too.
1967 C10 LWB 250 6cyl 3ott Panaramic cab “Layla” 1967 Camaro 327 ‘glide cruiser “Bailey” |
Member #1049
Two 30 gal drums, a railroad tie, a few 4X4's, two tall jack stands, a chain with hooks and an engine hoist. Then left it sit that way until the chassis was converted to 2WD.
#15 | |
I am glad CG started this thread. Livrat When I was 15 years old I use 55 gallon drums and a lot of 4x4 to swap the frame on my Impala. ![]() .
#16 |
Well I don’t know how strong 💪🏼 you are lol but this is how I did it by myself. I first built some low to the ground wood frames and casters. Lifted one side of the cab (did the box the same exact way) and slid the wood frame under one side. I used a jack and a long wooden 4x4 to lift the opposite side. I don’t have any suspension on my frame so I was able to drop the frame to the ground and slide it out. Then I lifted the side that’s supported by the wood frame up and push the WF towards the side supported by the jack and 4x4. That’s it, a little shimmy and done. I have a few pictures of the process on my IG C10_Steve if you wanna see. Hope you understand my gibberish 😂😂
#17 | |
BlahBlahBlah
#18 | ||
"I ain't nobody, dork."
Case of beer and 4 to 6 friends. So, muscle power.
Gary
#19 |
BlahBlahBlah
Large Cranes, large electric hoists, and sizable groups (more than two) of friends dont really fall into what I’m looking for.
One or two guys figuring out home style mechanical ways to accomplish this task. I think one of those home folding engine hoists qualifies though. |
#20 |
![]() Join Date: Aug 2019
I have done it all by myself. Just takes a long time. One bottle jack, 2 4X4's, 2 sets of saw horse's and a lot of cement blocks for cribing.
#21 |
When I had the body off my Chevelle I did the railroad tie technique mentioned above with two floor jacks (one on each end of the railroad tie).
One other trick was to use bare steel wheels to roll the chassis in and out. Not only does it keep the whole affair lower but you can scoot it side to side when lining it back up to go together. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#22 |
Here ya go. Put chassis on jackstands as high as it’ll go. Build a structure, unbolt and lower chassis down and simply drag it out. Just don’t forget to cross brace it. Also used the Lowe’s “cold lumber” that’s 75% off
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
#23 |
That's what I did. It is actually called "cull" lumber. And don't settle for 75%. They can go to 90%.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#24 |
Don't try this. I did and they wouldn't come apart so I junked it
#25 |
All about them K’s
![]() Join Date: Jun 2014
This is how I removed and installed the cab on my K20. I know I cheated big time. In the past I’ve built 6x6 A frames for either side of the cab And lifted it off the frame with a 4x4 through the door opening with nylon lifting straps on the ends. You have to run a 2x4 or similar over the roof to keep the straps from bending the drip rails. I just a block and tackle type setup to do the actual lifting. The latest way I did it is a lot easier.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
